Old 02-15-2010, 09:46 AM   #1
1971 27' Overlander
Port Deposit , Maryland
Images: 11
Need a aluminum tube for my Zip Dee
Freak rain storm came up and dumped so much water on my awning that the tube bent in half. it is beyond the pound out stage. I tried to put a sleeve over it and rivet it but it has to manually rolled up. I need to replace the tube but can't find a 3 inch 17 foot tube. Does anyone have a supplier that is on the east coast?
Lifeisgood is offline   Reply With Quote
Old 02-15-2010, 10:25 AM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
hmmm,
sounds like you're past this stage - Awnings By ZipDee
this may be helpful to you - Awnings By ZipDee
given its size, that tube will probably have to come to you via motor freight.
at a guess, and based on my own experience this past August as to the availability of a large Zip Dee part from a dealer, I'd otherwise suggest trying the factory directly, as I did.
otherwise, I'd tell you that I've had generally very good experiences with parts from Colonial Airstream in NJ, and Out of Doors Mart in NC.
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 02-15-2010, 10:33 AM   #3
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
also, the parts diagram noted that that tube is 3" 18 ga. galvanized steel, not aluminum, if you're going to try to fabricate the part yourself.
just thinking out loud, depending on where the bend is along the tube vs. the rest of the hardware, you might also be able to cut out a section & patch your bent tube instead? or, could you splint it from the inside with some schedule 40 or 80 plastic tube?
Joseph & Gabrielle
Old 02-15-2010, 12:18 PM   #4
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
You might give these guys a call.
COLAW RV PARTS & SALVAGE | WE HAVE YOUR PART!
Garry
Old 02-15-2010, 12:35 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Zip Dee parts
Awnings and related Repair Parts : ODMRV , Out-of-Doors Mart
Old 02-15-2010, 04:04 PM   #6
1971 27' Overlander
Images: 11
I call zip dee today and they gave me the spec's for the tube and you are correct that it is 18 gauge and steel. I have already taken a 3" dryer sheet tube and rivet it to the out side as a splint but that add to the bulk in the middle which prevents an easy roll up. That is why I have to roll it up manually now. I wonder could the bent section be cut out and another section be welded in?
Old 02-15-2010, 05:24 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I don't see why not. Also, it might be stronger instead of welding a piece in the middle to weld a piece to the end.
Old 02-16-2010, 05:45 AM   #8
1971 27' Overlander
Images: 11
The bend is right in the middle so I guess i could cut a foot out and weld together then add a foot on the end.
Old 03-01-2010, 07:55 PM   #9
Jacksonville , Florida
Smile
check out Jacksonville Florida craigslist under rvs, there is a 18 foot tube posted for $150. posted on 3/1
Canuck eh! is offline   Reply With Quote
Old 03-02-2010, 07:25 AM   #10
1971 27' Overlander
Images: 11
Thank you for the info for the tube in Jacksonville. I have contacted them and if needed I will drive there and pick it up. wonderful
Old 03-02-2010, 08:28 AM   #11
Kevin245's Avatar
We are scheduled to travel through the Jacksonville area on March 12th. If things work out for you we could possibly pick it up for you on our way back and you could pick it up here in Charlotte.
Kevin
Eleanor Roosevelt
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee Inland RV Center, In Commercial Listings 0 08-27-2007 10:06 AM
Zip Dee shinola345 Awnings 3 07-19-2006 10:51 AM
Zip Dee Inland RV Center, In Commercial Listings 1 07-13-2006 03:31 PM
Zip Dee, Why? Jabba Awnings 7 02-07-2003 05:35 PM
