Old 07-03-2016, 05:44 PM   #1
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
My Zipdee power awning
Well I think I might have figured out what my problems are with the awning. The green plugs that send power out to the motors doesn't have locking clips to hold them in the control module. If I push up on them the unit clicks and the awning works properly. I am stationary so it's not getting loose from traveling. SO I am going to relocate the unit to the floor and get long wire ties to hold the plug tightly to the controller. Since I am in the middle of the Yellowstone national park it will take me a week or two before I get out to a store but wanted to post this now in case anyone else is having strange problems with theirs and can try it faster than me and post their results. Fingers crossed
beetlebob is offline   Reply With Quote
Old 07-03-2016, 06:16 PM   #2
2015 28' International
Ofallon , Missouri
Really??!!
Sorry about your problem.
But you have a LOT of gall bragging you're in Yellowstone when many of us on the forum are trapped at work!! Aaarrrrggghhhh!
Obviously kidding! Good for you! I have 8 weeks of work left until I pull chocks and we hit the road. Starting with a retirement celebration trip (Redwood NP, Yosemite, Kings Canyon, Grand Canyon). Then have numerous planned after that - FL Keys in winter, 4 corners area in fall, Maine and Acadia NP.
So many great places so little time!!
Have fun and be SAFE!
mpsgolf is offline   Reply With Quote
Old 07-03-2016, 06:47 PM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
7,650' , Colorado
Zip Dee had some bad circuit boards which can be replaced under warranty. The most up to date boards have a green sticker, if yours is orange, check with them about your problem.
This is the strangest life I've ever known - J. Morrison
The Nest Egg - 2015 Airstream International Serenity 27FB
mojo is offline   Reply With Quote
Old 07-03-2016, 07:06 PM   #4
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Yellowstone, nice, ZipDee, not so nice. My sob had power awning, it was so easy to just push that button, now on AS we never put awning out.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 07-03-2016, 07:43 PM   #5
beetlebob's Avatar
2015 30' Classic
It is the new board. Never had a problem with the old one not staying plugged in
Old 07-03-2016, 07:50 PM   #6
2016 30' Classic
Lorton , Virginia
Thanks for the tip, Checked mine and the sticker is green. So far no issues with the awning.
Zybane is offline   Reply With Quote
Old 07-04-2016, 09:41 AM   #7
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Bob, unscrew the actuating pad. Then unplug the RG cable from the rear of the switched. Look inside the female socket and make SURE that none of the connectors are bent and that each will make appropriate contact when you plug in the male connector. I'd do this for every RG socket. Think that may solve the problem. Barry
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-04-2016, 09:56 AM   #8
2015 30' Classic
Pleasanton , California
I contacted ZipDee regarding the accidental openings that have occurred and firmware changes. From my understanding, the green stickers identified that the controllers were fitted with the lastest firmware version. The latest version addressed an issue where motors could potentially burn-out at low voltage conditions. Unfortunately, there were no firmware changes to address accidental openings.
My own suspicion is that the screw-on connectors on the controller board and the relatively stiff wires powering the controller work themselves into an intermittent contact while on the road. Like others, I added a SPST switch to disable power to the controller when not in use. ZipDee said they were planning to modify the actuator panel to include an ON/OFF switch in the future.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 07-05-2016, 06:59 AM   #9
beetlebob's Avatar
2015 30' Classic
Yes I am in Yellowstone until September but I am also working 40 hours a week. I am fixing the broken down cars and RVs that come to the repair shop that I am at. As far as the awnings opening on their own there's only 2 reported cases of this and I feel it has been over used to much. From the start Zipdee said it needs a power off switch. I feel if they said that that they should of had one on the button panel but go figure. I have been checking and working on my awning since my trailer was 2 months old and getting tired of it. Nate at the factory has been very helpful and I feel he cares. Jimmy on the other hand doesn't. I have done automotive electrical work for over 30 years and my dad was an electrician so I feel I know what I am doing. I have found some wire ties and will try my fix on my next day off and let you know. Living in Yellowstone is nice as long as you don't have to work on your days off on your own trailer
Old 07-05-2016, 07:27 AM   #10
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I'll bet you are a local hero to those who need you, beetlebob. Thanks for being there in case I need you!
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
wbcci 9239 (Re-enlisted 2013)
pmclemore is offline   Reply With Quote
Old 07-13-2016, 06:45 PM   #11
beetlebob's Avatar
2015 30' Classic
Well finally got around to working on the control unit. Mounted to the floor and used wire ties to hold the pins in tight to it. I have never seen it run this good. For once in over a year I like my awning. Will let you know in the next few months if I still do
Old 07-15-2016, 06:00 AM   #12
2016 30' Classic
Hilliard , Ohio
Bob, this is the 2 layer terminal that all the (9?) wires are attached to (color blind)? Did your issue also coincide with some of the status LEDs out on the upper-left corner of the board? My dealership replaced the board with a new one, but still couldn't get it to work. JC told them to have me bring up there next month, but wanted to give it a shot myself.
2016 Classic
2010 Ford F-150 Lariat
jeff4506 is offline   Reply With Quote
Old 07-16-2016, 07:38 AM   #13
beetlebob's Avatar
2015 30' Classic
Yes it is the 2 plugged in connections BUT. Even though the awning is working good it STILL never shows that it is closed????? Will contact Zipdee again and see what they say. This is the 4th time with this problem.
Old 07-20-2016, 01:20 PM   #14
beetlebob's Avatar
2015 30' Classic
Well awning still not right. Spent some good quality time with Nate at Zipdee He is very helpful and I feel cares. The new control unit that the factory installed is bad. They are sending me another one and we will go to round 5 of the power awning saga
Zipdee Awning Feedback Airboutique Awnings 2 01-22-2011 04:28 PM
ZipDee Awning Spring Stop Rivets Question 3blessed Awnings 0 06-16-2010 08:43 AM
Airstream ZipDee window awning for '65 Caravel 76sovereign 1965 Caravel 1 08-03-2008 06:40 PM
How much should a 16ft ZipDee Awning cost? Silverfly Commercial Listings 3 07-13-2004 05:20 AM
