Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 10-04-2010, 08:32 AM   #1
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 26
More EZ-AWN info
Just got my 'recycled' EZ-AWN mounted and thought I'd post these pics since there doesn't seem to be a lot of info floating around about these old units.
I had to fabricate the brackets and shorten the tube and fabric to fit my trailer.
also ended up pre-loading the springs at about 4 rotations before it seemed to work right.
hope this helps.
ID:	112337   Click image for larger version
Doug
59er is offline   Reply With Quote
Old 10-14-2010, 08:30 AM   #2
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
I finally, what really matters...In-use.
Doug
Old 10-14-2010, 06:32 PM   #3
Silver Mist
LI Pets's Avatar
Riverhead , New York
I also did a retro fit.
I love the curved arms much better than zip dees, but you only took up 4 turns is that correct?
How long is the awning?
Old 10-15-2010, 07:14 AM   #4
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
the awning tube is just under 16'. and now that I've had a chance to use it, I think I may back off to 3 turns each (pre-loading the springs).
I helped a friend replace the fabric on his carefree (70's model) and we tried several different numbers before realizing that it needed to be installed with no tension (when in closed position/up against the camper). it tensioned as we pulled it out, and retracted fine? tried that on this EZ-Awn first but it needed help gettting back to the closed position with a nice tight roll.
what did you end up with?
Doug
Old 10-21-2010, 09:46 AM   #5
keith53's Avatar
1979 24' Airstream Excella 24
barnehurst , Kent. UK
I agree these look so much better than the Zip Dee, you havn't got the piece you cut off have you? I,ve got one that's a bit short on the tube.
keith53 is offline   Reply With Quote
Old 10-27-2010, 12:49 PM   #6
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
I used the drops for an inside sleeve to re-enforce the tube. it was cut in the center and had to be welded back. long story. happy ending.
show me a picture of what you need (with a ruler or measuring tape and I can probably get you a scrap of just about any size if you think shipping it to UK would be worth it).
Doug
A&E Travel Awn 5000 uwe Awnings 11 07-05-2016 07:33 AM
EZ AWN by Atlas Enterprises??? max7 Awnings 10 05-05-2009 12:09 PM
RV info mijoda52 General Motorhome Topics 2 07-10-2005 09:40 PM
E-Z Awn and leak?? jmark71 Awnings 2 05-16-2005 07:37 PM
Help - How do I open My Travel-Awn 5000? PaulaJ999 Airstream Motorhome Forums 4 04-25-2003 04:27 PM
