Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 01-30-2008, 07:05 AM   #1
chris's 67
Profile:  1967 24' Tradewind
gilbert , South Carolina
Missing support arm for 31' 76 sovereign
I'm missing a piece of what I assume is a middle support arm for the awning. There are brackets located on the side of the camper in the middle. If anyone could tell me the function of this piece and where I might find one I would appreciate it. A picture would also be appreciated.
chris's 67 is offline   Reply With Quote
Old 01-30-2008, 08:46 AM   #2
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
Our 31 foot 77 came with a Zip Dee but did not have the support rod. I found one at a Swap meet at a region rally and installed it. It did not seem to improve the awning performance. A couple of years later I noticed it had torn loose when going down the road and there was no way I was going back 300 miles to find it. I have not bothered to replace it. Since your awning is much shorter, I do not think you should bother to replace it. I always tie my awning down if I am going to be away for the day. Using the rally setting to tip your awning will guarenttee that water will not collect in the middle and bend the main roller.
Old 01-30-2008, 09:58 PM   #3
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
The middle support arm slides out just like the end pieces but there is a nipple on the end of the rod that fits into a hole drilled in the awning tube. It's function is to help support the long awning tube on longer trailers. Sorry I do not have a picture since the trailer is in Hamburg, Germany now.
Contact Zip Dee to see if they have replacement arms or Colaw Salvage (do a search on the forum for location/website) for used units.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-31-2008, 05:48 AM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
I can take a picture later this evening if needed. Our awning has been out for months, and I have not put that arm out. no problems.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
'78 31' Sovereign 87MH 1978 Sovereign 66 02-23-2008 08:30 PM
31' 73 sovereign - Where to begin? GreenApple General Repair Forum 11 01-20-2008 06:51 AM
1978 Sovereign 31' Value Okie Guy Trailer Values 6 06-29-2006 09:38 AM
interior for 31' Sovereign dragonfly Parts Archive 32 01-07-2005 10:53 AM
Idler arm support assembly PeterH-79MH Mechanics Corner - Engines, Transmission & More... 0 09-11-2002 08:53 PM
