Old 06-06-2016, 05:57 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Main Awning End Lock Alignment
It is as if my awning is about an inch too long. I have a 2002 Classic with the rotary wheel locks on each end. When I roll the awning up the part of the latch that the wheel center shaft (the wheel part, not the threaded rod) is supposed to recess into is a full diameter of the shaft out of alignment. It is so far out that it is difficult to screw the wheel down without the shaft popping out of the recess it is supposed to go into. The problem typically occurs at the rear latch even though I hook the travel latch first and then the rotary end latches. The front one lines up reasonably well.
The fact that the the rear one is the problem and it is so close to the hook latch would seem to indicate a problem with the rear rotating joint. Is there any kind of wear or failure that would allow the end to move out a half inch or more? I checked as best I knew how and it is firmly attached.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-06-2016, 08:07 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Al,
Had the same problem on our Classic.....turned out the rear main support arm was not mounted plumb. As a result the awning rolled up off center and the lock wouldn't line up.
Moved the arm forward 3", now the arm flowwows....problem solved.
ID:	263982   Click image for larger version
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 06-06-2016, 08:21 PM   #3
Thanks Bob. I never even thought of that. In my case, it looks plumb, there seems to be enough slack in the end fitting to accommodate the offset, but I bet if I move it forward an inch or so it will solve my problem.
Al
S/OS #004
Front end alignment shepherd57 Classic Motorhomes 9 06-22-2015 07:07 PM
Awning lock latch alignment adjustment help exallen Awnings 18 02-21-2014 12:18 PM
Front End Alignment shepherd57 Classic Motorhomes 2 09-30-2013 05:22 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
front end alignment wb13798 Mechanics Corner - Engines, Transmission & More... 2 12-11-2003 12:11 PM
