Old 08-11-2016, 10:13 PM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Looking for advice on removing awnings
I'd like to strip the failing clearcoat from my 29' 1992 Excella. I have full-length awnings on both sides and also one over my rear window. I want to remove them before doing any stripping, but I'm worried about springs, tork, etc.
I sure like some advice on how to do it safely.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 08-11-2016, 11:33 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I removed mine. It was easy. I rolled it out. Unwound the spring with the rafter arm. Drilled out the rivets holding the fabric to the tube. Slide the tube out of the awning fabric pocket. Took out a screw on the end of the awning cover and slid out the awning fabric with one slat of the cover still attached to the fabric....it took about 20 minutes and two people.
CRH is offline   Reply With Quote
Old 08-12-2016, 07:22 AM   #3
Re-Pete's Avatar
1992 29' Excella
Thank you, will I need a tool for rewinding the springs when I reinstall the awnings.
Sorry for possibly dumb questions, My Airstream is currently in a storage lot, so I can't just check, how do I know which side the spring is on?
Pete
Virginia Beach, VA
Old 08-12-2016, 07:31 AM   #4
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark , Delaware
You don't need a tool to wind your awning spring. It is done with the rafter arm. Just be careful as the spring tightens to not let go because it will spin like a propeller.
Chatooga11 is offline   Reply With Quote
Old 08-12-2016, 09:02 AM   #5
1971 31' Sovereign
Palm Desert , California
The Zip Dee website has detailed instructions.
CaCraig is offline   Reply With Quote
Old 08-12-2016, 09:08 AM   #6
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Echo this...although it is a propeller that is typically stopped after one revolution as the arm bashes into the side of the coach!
martin300662 is offline   Reply With Quote
Old 08-12-2016, 12:58 PM   #7
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
http://awningsbyzipdee.com/media/DIR...efffffd524.pdf
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 08-12-2016, 02:49 PM   #8
Re-Pete's Avatar
1992 29' Excella
i found the pdf's on the Zip Dee site. I even called Zip Dee and got a quote for new fabric as my awnings are getting a bit long in the tooth. I'm not saying they're shot, let's just say I can attest to the effectiveness and awesome holding power of awning tape.
Pete
Virginia Beach, VA
Old 08-12-2016, 03:01 PM   #9
Re-Pete's Avatar
1992 29' Excella
Originally Posted by DavidsonOverlander View Post
Thank's for the link.
Yeah, I found out about the propeller effect the hard way working on the Butt Awning a month ago. I was replacing the thin plastic rub rail around the verticle midway point. I was really careful when I removed the right strut and there was no tension. I got careless and forgot to be careful removing the left strut and got whomped pretty good. Fortunately, I was positioned so that I and not the AS took the hit. So, no dents other than to the government plastic in my head. Really messed up my part, though.
Pete
Virginia Beach, VA
Vintage style awnings (martys awnings) LUCKYDOGNOLA Airstream Classifieds 0 03-25-2014 12:04 AM
Vintage Looking Awnings... InsideOut Awnings 143 03-15-2007 01:00 PM
Removing Old Awnings Tin Lizzy Awnings 13 08-29-2006 01:32 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 11:47 PM
