Old 07-18-2005, 06:51 AM   #1
JohnGalt48's Avatar
1977 31' Sovereign
"leaky" awning....
My Airstream still has it's original awning in place, and it is in pretty good condition.
The only "problem" is that when it rains, the water just comes right through it.
Is there something recommended that I could easily apply to it to waterproof it?
Guy
JohnGalt48 is offline   Reply With Quote
Old 07-18-2005, 07:27 AM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I have an awning from a '66 Overlander on my trailer and it leaks like a screen. I bought a gallon of Camp-Kote from Sportmen's Warehouse. Label says its water and stain repellent. I applied it with a hand pressurized tank. Hasn't rained since being applied so I can't tell you how it works. I'll post the results if it ever does.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-18-2005, 10:25 PM   #3
_
hold off on the water repellant
john
zip dee usually advises against applying anything to the cloth, except when cleaning.
often the acrylic fiber dries out so much that leaking is common....mine 25 year old curb side did the same thing.....
so try this first......open the awning completely and wet it down completely with a fine mist low pressure setting. really soak it good from the top and bottom.
wait 30 minutes and repeat.
if the awning is soiled at all now wash it with a wide soft brush, mild soap/water and repeat the wetting step. if it's not at all soiled just wet it for the 3rd time.
roll the awning back up while wet......that's right while wet.
wait 24 hours
open awning again and check for "rainproofness" with a water hose stream rolling gently over the surface. fibers should have had time to reexpand and recover their original function.
of course if you have small holes or big gaps in the fabric....it might be time for new cloth.
also i think zip dee now markets a product for awning coating?
check their web site.
cheers and let us know what happens
2air'
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Awning Heads Up!!! JaceBeck 1999 Safari 39 04-25-2006 05:31 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Awning gwrimmer General Motorhome Topics 1 11-07-2002 11:59 AM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
