Old 11-09-2018, 02:59 PM   #1
1988 29' Excella
Austin , TX
Leak at Awning Rail
I'm chasing a couple of leaks that I believe are coming from the curb side awning. I've attached a picture of the rail and have a couple of questions. For some reason the picture is rotated 90 degrees - My thumb is pushing down on the roof.
1) As shown in the picture, when I press down on the roof at a point between the rivets, the skin depresses and separates from the rail. The old caulk is obviously not doing much good here but with this much give will a new bead of caulk do any good or is there something more that I should be doing? Note that the rivets securing the rail to the roof are about 9" to 10" apart.
2) Should I remove and reinstall the rail? If I do, should I place some Butyl or VHB tape under the rail?
Note that I plan to cover the edge of the rail with Eternabond tape so I'm basically trying to figure out what I should do before installing the tape.
Also, I don't really want to replace the rail but more then anything I want to stop the leaks, so my goal is to do it right and not have to deal with it for years.
Thanks!
John
JohnnyAustin is offline   Reply With Quote
Old 11-09-2018, 04:23 PM   #2
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
That joint should be caulked down the whole rail. I would not remove the rail.
I’ll try and get you a photo of what mine looks like when I get home from hunting.
GMFL is online now   Reply With Quote
Old 11-10-2018, 08:13 AM   #3
1988 29' Excella
Austin , TX
Thanks! That will help a lot. I've never owned an AS before and have only had this one a couple of months, so I'm trying to get this thing fixed up with a serious lack of experience ;-)
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 09:27 PM
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 03:37 PM
awning rail leak and removal.. Bill M. General Repair Forum 18 04-24-2013 09:10 AM
Awning rail "snaps" bevman Awnings 2 08-15-2007 09:55 PM
Found The Awning Rail...yikes! happydaze Awnings 1 04-29-2006 11:32 AM
