Old 08-17-2010, 05:44 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Installing Zipdee window awnings
Howdy,
Summer is almost over and I'm getting ready to install salvaged window awnings on my 71 25' Tradewind, roadside and in the rear. I am planning on one long awning roadside that will shade all three windows and a little bit more. The distance from the front of the front window to the back of the 3rd window is 12' I am planning cutting down a 20' awning to a length of 14' Any advice on the following will be greatly appreciated:
1. How do I attach the awning rails to the coach? Olympic rivets and Vulkem?
2. Where should the awning rails and the arm brackets be located, measurements?
3. The stove vent will be above the awning. Will I run into any problems there?
4.The rear awning I have is about 50" long. My rear window is about 45" wide". Am I thinking correctly I should shorten the length of the roller to 45" so I can attache the lower brackets into a rib, not just the skin and the awning rail will be on a straight line and not the curve of the corner?
5.What kind of fasteners to attach the bottom awning brackets?
Marshall
Lumatic is online now   Reply With Quote
Old 08-17-2010, 06:14 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
That's what I used.
I had to fit mine between the windows and the stove vent. Not a lot of room to work with, but it did fit. My awning runs from the first vertical rib to the last vertical rib. The arms are riveted to the vertical ribs.
It was close on mine, but I have a different vent.
Attaching to the ribs would be a better way to go, IMO.
Since I ordered mine new, it came with the hardware. The rivets are oversize flathead rivets with a solid stem. I think these are the ones that came with mine: Rivet, Large Olympic LOR - $0.39 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Here is the thread that shows my window awning install:
http://www.airforums.com/forums/f442...ing-51914.html
Richard
Old 08-17-2010, 07:50 PM   #3
_
hi marshall
follow DA LINKS in this thread...
with a very good DIY and a masterTECH each doing installations...
http://www.airforums.com/forums/f442...5-a-57587.html
when in doubt z/d also has printed directions for installation.
cheers
2air'
Old 08-17-2010, 08:42 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
Thanks 2air and Richard. That pretty much answers all my questions. Now I guess I will have to do the install before the next rally with Richard. Hey wait, I could bring the parts and the tools
Old 08-17-2010, 09:35 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Richard,
Your photo on the other thread is exactly what I want to do. Moreover the stove vent looks the same. If you have the time can you tell me what the measurement is from your window gutter line and the bottom line or rivet line of your awning rail and the measurement from your window gutter line and the bottom of your stove vent.
Old 08-18-2010, 07:49 AM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Would youse recommend installing a travel latch on the rear as well as streetside window awning?
Old 08-18-2010, 08:18 AM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
my street-side awning (zip-dee) doesn't have a travel latch. didn't even know there was such a thing.
I'm surprised that you can find a "salvaged" awning. I've seen rear-window awnings on e-bay...but I would think that most salvaged 'streams would have likely been rolled, and in which case, any long awnings would be pretty badly damaged. (?)
I'd love to replace my care-free patio awning with a zip-dee, if I could find a used one.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-18-2010, 10:02 AM   #8
2007 25' Safari FB SE
Eureka Springs , Arkansas
Chuck,
I found salvage cases, roller tubes, etc at Colaws.
Yes, you have to pick them carefully as many are rolled.
I'm getting new canvas, so it all matches.
triplenet is offline   Reply With Quote
Old 08-18-2010, 11:49 AM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
Marshall,
I will get those measurements after work and post them. My streetside awning came with a travel latch and I installed it.
Richard
Old 08-18-2010, 01:36 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
Every now and then they are on ebay. Shipping on the long awnings is the killer.
Old 08-18-2010, 08:37 PM   #11
2002 25' Safari
Dewey , Arizona
Images: 62
Here are the numbers for my awning rail install.
First of all the awning rail which was provided by ZipDee is 1" tall and the awning attaches to the very bottom of the rail. The top of the rail is 5/8" below the bottom of the exhaust vent cover. The bottom of the awning rail is 2 5/8" from the top of the windows.
I could have moved it up at least 3/8" higher because the awning roller sits below the top of the awning rail. This would have given me a little more room with the windows, but as it sits now, everything sits fine.
Richard
Old 08-18-2010, 09:50 PM   #12
Lumatic's Avatar
1993 34' Excella
Images: 16
So I could move the awning rail up so the top on the rail is flush with the bottom of the vent cover?
Old 08-18-2010, 09:56 PM   #13
2002 25' Safari
Dewey , Arizona
Images: 62
I don't see any reason why not. The roll would still not come close to the vent.
Richard
Old 08-22-2010, 06:51 PM   #14
Lumatic's Avatar
1993 34' Excella
Images: 16
Rear Window
OK, I think I got the roadside window figure out. Now for the rear.
I have a window awing from a newer Airstream that is about 50". My window is about 45". I have to cut it down so the curve on the end of the trailer, and the ribs by the window line up for a secure installation. No big deal.
As I was contemplating my rear end, two questions came to mind:
1. Where should the awning rail be mounted in relation to the clearance marker lights.
2. The last couple of inches of the awning rail will be above the curved corner of the window. This is where the skin begins a compound curve.
Do I:
a. fasten the awning rail ends flush with the skin with a slight bent
curve
b: add a shim to fill the gap at the end of the awning rail so the
awning rail is flat, or
c. Leave the last couple inches of awning rail free floating.
Any one else have this issue? What did you do?
Any recommendations for rivets to attach the awning fabric to the roller tube?
Aluminum Window Awnings JimGolden Awnings 9 11-26-2015 12:14 PM
Whose window awnings are these? wmheinz Awnings 2 05-18-2010 06:58 PM
Installing a Zipdee on a '71 Lumatic Awnings 6 07-30-2009 07:12 AM
Airstream ZipDee window awning for '65 Caravel 76sovereign 1965 Caravel 1 08-03-2008 06:40 PM
Ordering Parts From ZipDee Awnings Safari-Rick Awnings 10 11-30-2007 08:50 PM
