Old 08-22-2010, 08:10 PM   #15
heslinhotel's Avatar
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Youngsville , North Carolina
Awning mount
I bought a salvage ZipDee from a 2006. I was planning to install on a 78, called ZipDee to get recomended instructions. I was transfered to a gal who had been there many yrs and she was a great wealth of info. Seems AS has changed location of ribs several times over the years on the same length models. Was very helpfull in informing me the exact dimensions I needed to be sure to be able to mount arms to proper location on the specific ribs. If you mount on skin they will tear out. Best of luck with the install.
heslinhotel is online now   Reply With Quote
Old 08-22-2010, 08:16 PM   #16
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Marshall...
Our street side and rear awning were added after market. The street side does have a travel latch near the front, but the rear does not have a latch.
For what it's worth... Our rear awning also goes beyond where the curve of the end cap starts...ours is free-floating for the last couple of inches on both ends... I think if they were bent to fit the curve it might affect the roll-up. You could probably fill in the space somehow if you want, but ours has none.
You'll love having the new awnings.
TB & Greg and Abbey Schnauzer
AirForums #21900 . Membership Chair, 4C
Unit #3954
Old 08-23-2010, 07:40 AM   #17
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
OK, Yeah, I'm bumping this back up to the top again. Here is what I am down to:
  • Where should the awning rail be mounted in relation to the clearance marker lights.
  • What size/type rivets to attach the awning fabric to the roller tube?
It sound like the Zipdee lady at referred to above is Linda, and I plan to call her this morning.
Old 09-03-2010, 09:05 AM   #18
Lumatic's Avatar
1993 34' Excella
Images: 16
Richard,
Hopefully the last questions:
How long are your window awning roller tubes?
How wide are your awning fabrics?
Thanks again and again,
Marshall
Old 09-03-2010, 09:48 AM   #19
dznf0g's Avatar
Oswego , Illinois
I read somewhere that Zip Dees over 10 feet should have a travel latch. Mine has them on curbside and streetside front. Not on the little single windows streetside and rear.
Old 09-03-2010, 10:06 AM   #20
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
When both my streetside awnings extended in a heavy side wind, the travel latches went on right away!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-03-2010, 06:42 PM   #21
Lumatic's Avatar
1993 34' Excella
Images: 16
I called Zipdee they said streetside (talking about a 14 footer)yes, rear no
Old 09-04-2010, 04:57 PM   #22
Lumatic's Avatar
1993 34' Excella
Images: 16
Just when I thought I had all the answers.
There is a line in the Zip Dee install instructions "wide grip rivets permit skin-only mounting of hinges".
I will be cutting down a salvage awning for the streetside and rear window awnings, so I can make them any size I want.
My rear window is riveted into the ribs which is about 44" wide. Should I rivet the hinges into the ribs and have about a 44" wide awning or rivet the hinges into the skin a couple of inches farther out for a wider awning? What do you think. If mount the hinges farther out, a couple of inches of the awning rail at either end will be free floating due to the curve of the back of the trailer,
Old 06-18-2012, 04:01 PM   #23
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I realize this is an old thread, but how did those awnings turn out? We are hoping to find street side and rear awnings for ours.
Skatiero is offline   Reply With Quote
Old 06-18-2012, 04:44 PM   #24
Lumatic's Avatar
1993 34' Excella
Images: 16
To tell the truth. I still have them in storage waiting for the time.
Old 06-18-2016, 05:44 PM   #25
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Following
Old 06-18-2016, 07:00 PM   #26
1976 31' Sovereign
Oswego , Illinois
awnings
You should never have awning rail floating at ends also IMO this makes a weak point subject to tear loose and cause damage and leaks.
Aluminum Window Awnings JimGolden Awnings 9 11-26-2015 01:14 PM
Whose window awnings are these? wmheinz Awnings 2 05-18-2010 07:58 PM
Installing a Zipdee on a '71 Lumatic Awnings 6 07-30-2009 08:12 AM
Airstream ZipDee window awning for '65 Caravel 76sovereign 1965 Caravel 1 08-03-2008 07:40 PM
Ordering Parts From ZipDee Awnings Safari-Rick Awnings 10 11-30-2007 09:50 PM
