Old 05-29-2006, 09:02 PM   #1
Alden Miller's Avatar
1993 34' Excella
, Maryland
How tight is too tight?
I just finished installing my last new awning. Zip dee (depending on which part of the installation instructions you read) says to wrap seven or ten wraps and then one wrap per foot of awning width.
I wrapped (tensioned the spring) 31 times for a 20' 9" awning. It just doesn't seem to wrap up as tightly as the old awnings.
So, how much is too much? can you tighten the spring more to compensate for age or am I looking for something to break if I do that?
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 05-29-2006, 09:34 PM   #2
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Put on an extra turn and then check it. As long as you don't go crazy everything will be fine. Be careful a runaway spring can be dangerous to you and the skin of the trailer.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 05-29-2006, 10:06 PM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Fairly easy..
Alden,
Several yrs ago, I redid the small awning over the side bedroom window.
As I recalled, I only turn mine abt 17 turns. You might not be too far off on your's. Supposedly, the spring and internal rod size are the same for all awnings. Just the number of turns requirement, which sepends on the length of the awning.
This web site for ZIP DEE explains it..http://www.zipdeeinc.com/RV Products/RV-adjust-spring-tension.html
It shows 27 turns for a 20 ft...
take care..
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-30-2006, 09:29 AM   #4
1993 34' Excella
, Maryland
Hmmm, I think I'll give Zip Dee a call. As I said, their instructions contradict themselves about the number of turns.
Thanks for the input!
-Alden
Old 05-30-2006, 09:08 PM   #5
1993 34' Excella
, Maryland
A quick call to the helpful folks at zip dee and the answer is at hand.
The guide they give (7 turns plus one for every foot of awning) is a starting point. They did caution that with an older spring that over tightening may cause it to break. No recommendations on the number of turns.
If it breaks a new spring is available ($108 + $20 shipping).
I'll put off trying to tighten it more until after we go to the beach next week.
-Alden
Old 05-31-2006, 02:44 PM   #6
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Hi Alden,
Thanks for the info as my parts are suppose to be in today or tomorrow...can't wait!!!
One question for you....They are saying 7 turns plus one for every foot of awning....try not to sound stupid but would that every foot be for the length of the awning tube or the lenght of the actual cloth being rolled onto tube??
Also ...I get great ideas in my sleep....I have to sew up the seam on mine to attach to tube...figured how am I going to do this??? I'm going to put my portable sewing machine on a rolling dolly in my driveway and move it slowly across the seam to be stitched...thought maybe someone out there might be able to use this idea.
Thanks again, Ann
enduroryda is offline   Reply With Quote
Old 05-31-2006, 03:13 PM   #7
MW64OVERLANDER's Avatar
1964 26' Overlander
Norman , Oklahoma
Images: 67
-Alden
Another helpful guide is to extend the awning fully and then let the pressure off of the pull. If the awning starts to roll up on its own, then you need to back off one turn and conversely, if a gentle push does not start it rolling up, then you can add one turn.
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
Old 05-31-2006, 08:46 PM   #8
1994 30' Excella
Mississauga , Ontario
Like Mark advises that is what I did with mine. When I bought my used trailer it was almost impossible to open the awning. I could barely hold it fully unrolled and get the arms hooked over the roller tube;and I'm 6foot three!
Read Zip Dees manual and released 6 turns from the spring tension. Now it is a joy to use.
Al
Old 05-31-2006, 09:12 PM   #9
enduroryda's Avatar
1994 21' Sovereign
Parts came in and the awning is on....looks sweet!!
Did 7 turns plus 6 because the fabric was about six feet out...so 13 turns.
Just had a nice cold one with the hubby under it
Old 05-31-2006, 09:36 PM   #10
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
I think you might need more turns. It's 7 turns because it's rolled out plus 1 turn for every foot in lenth. Your awning is about 11 feet long + 7 = 18. That is a starting point. You want it to stay when rolled out, but roll up when you start to push it back.
Richard
Old 05-31-2006, 09:39 PM   #11
enduroryda's Avatar
1994 21' Sovereign
man......... that's the info I was looking for earlier...thank you AZ
Old 06-01-2006, 12:27 PM   #12
1993 34' Excella
, Maryland
Sorry, I have been busy the past couple days.
azflycaster is correct, it is 7 turns plus one turn for every foot of width of the awning.
I installed my second and third awning a little differently than the instructions from zip dee.
I first unwound the tension from the tube. Then removed the old awning and slat. I attached the awning to the slat and installed it back on the trailer. Then I removed the tube from both awning arms and slid it into the awning. I re-attached the tube to the arms and wound the spring for tension.
I found this much easier to control than trying to slide the awning into the slat and onto the tube at the same time.
-Alden
Old 06-01-2006, 01:00 PM   #13
enduroryda's Avatar
1994 21' Sovereign
I had to pretty much rebuild mine...Took mine off the top rail by sliding the roller cover out...pole was already off for the sewing repairs needing to be done to awning. I then installed a well WD'd rail back in place..then slid pole back in and riveted it. Then spring ...then arms,
I have 13 turns on mine...my pole is 12' so looks like another 6 rotations. That should give it quite a bit of tension...that follow up project is tonight when I have more hands.
It was pretty easy I think so if anyone out there is debating on taking this job on I'd say go for it.
Thanks for the help Alden & AZ!
Old 06-01-2006, 04:15 PM   #14
_
hi canvas'er
with new springs it is wise to use them a bit before unwinding....
i've noticed that afteer 15-20 prolonged deployments that the springs relax a little, so what previously rolled up quickly now will stay out better.
i mention this because
if you ever need to take up the awnings in winds....
you DO want them to rewind smartly....
too loose and the awning will rise like a sail!!!
cheers
2air'
HELP!!! On a tight schedule, need to replace floor from front to rear... JeepinAudiophile Repairing/Replacing Floor &/or Frame 73 06-21-2008 11:34 AM
Now That's a Tight Fit! Porky Pig On The Road... 57 02-12-2006 05:55 PM
Keep hubcaps tight RichardT Off Topic Forum 16 10-27-2005 08:41 PM
Tight squeezes~! 53flyingcloud On The Road... 14 09-25-2003 07:38 AM
Length of and Airstream Ed & Nancy Our Community 27 02-18-2003 09:34 PM
