Old 06-01-2006, 06:40 PM   #15
1983 27' Excella
French Settlement , Louisiana
I just got around to fixing my bent awning tube
I tryed to fix on traler but could not so I removed the tube and straighten it.It was hard to bend on the trailer.It is a lot better now I think I may tighten it up in a few days about two or so rounds.
Does anyone know when stripping the clear coat off a trailer it it will hurt the awning and what they do about the awnings
Billy
housebg is offline   Reply With Quote
Old 06-01-2006, 08:56 PM   #16
lewster's Avatar
Naples, FL , Hood River, OR
A Little Secret
Hey Gang,
With all this talk of awnings, there is a little known trick to keep those awning springs in top shape and delay the on-set of rust. Rusted springs are the major reason for spring failure in roll-up style awnings. When ever you get a new awning or replace a worn spring, coat the spring with a waterproof grease, silicone spray, battery terminal sealer or DuPont Dry Teflon lube (the best IMHO).
This will effectively seal the spring against water intrusion and rust and will make it last far longer than a bare spring!
Old 06-01-2006, 09:09 PM   #17
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Not to get off the subject..
Billy
Billy, the norm for stripping is to remove the awning completely but..I'd venture a guess and, say that' just doesn't happen often..You can leave it on, just be careful when you apply the stripper~Work slowly and have a clean rag handy for quick rescue..
Let me add this, just in case someone reading this mis understands..
I wouldn't advise stripping the metal cover part of the awning itself..
Sounds like you're about to go for it...
HAVE FUN~!!
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
HELP!!! On a tight schedule, need to replace floor from front to rear... JeepinAudiophile Repairing/Replacing Floor &/or Frame 73 06-21-2008 10:34 AM
Now That's a Tight Fit! Porky Pig On The Road... 57 02-12-2006 04:55 PM
Keep hubcaps tight RichardT Off Topic Forum 16 10-27-2005 07:41 PM
Tight squeezes~! 53flyingcloud On The Road... 14 09-25-2003 06:38 AM
Length of and Airstream Ed & Nancy Our Community 27 02-18-2003 08:34 PM
