Old 05-29-2008, 05:51 PM   #1
magna1111's Avatar
1978 31' Excella 500
Eureka , California
How safe is this? How to fix?
While recaulking the new old airstream, I noticed the awning connection looks dangerous, what type of screws would i have to find to fix this? Is that silicone block suposto be there? Anyother tips? Is is safe to take on a trip this weekend?
Ty
Will the work ever end...
ID:	61320   Click image for larger version
magna1111 is offline   Reply With Quote
Old 05-29-2008, 06:07 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have seen stainless steel screws used.
Old 05-29-2008, 06:10 PM   #3
magna1111's Avatar
Eureka , California
The screws look unusual
The screws look like no other I have seen, wonder if they have a special name, they seem to have a case where the threads would be.
Old 05-29-2008, 06:13 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Ty
magna,
You have one 'chocolate mess' on your hands there!
If I were you, I would:
1* remove the 2 screws that hold the awning bracket on
2* definitely remove ALL of that silicone (which has NO PLACE on an RV!)
3* clean the area as well as you can with appropriate solvents to get the metal-to-metal junctions as spotless as possible
4* find an appropriate size stainless sheet metal screw (probably a #10 or 12) that will be just slightly oversized for the existing holes
5* re-attach the bracket and butter the back with a liberal coating of SikaFlex 221 or Vulkem in grey
6* tighten the 3 screws (the missing one looks like it should perfectly intersect the rib behind the rivet line
Carefully clean the sealant squeeze-out.....and you're DONE!
Let me know if you have any other questions
Old 05-29-2008, 10:04 PM   #5
magna1111's Avatar
Eureka , California
thank you
Nice site Lewster and thanks for the information from you both, I was hoping that silicone block had to go. Have been removing old silcone with silicone remover all day. I will attempt your fix tomorrow. Thank you again.
PS does your metal business cut aluminum patches? I have a nice 9 inch slice I would like to patch with an interesting shape.
Old 05-30-2008, 05:37 AM   #6
lewster's Avatar
Actually, my alter ego is that of a custom goldsmith making fine jewelry. Have been for almost 35 years...............but no aluminum
Is It Safe?? ROBERT CROSS Batteries, Univolts, Converters & Inverters 5 12-02-2007 07:25 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Short term fix, is it safe enough? Mike & Deb Tires 7 12-30-2004 04:10 PM
How Safe is 53flyingcloud Off Topic Forum 18 07-31-2003 03:11 PM
