Old 09-15-2011, 09:10 PM   #1
1981 31' Excella II
New Market , Alabama
How much is a new awning for a 31 footer?
I was wonder about how much a new Zip Dee awning canvas would be for a 31 footer. I expect they are not cheap. Can you buy the canvas and install it yourself? My awning still works but the seams are rotting and the canvas has in a couple of places as well.
Perry
Old 09-15-2011, 09:19 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can buy the fabric and install it yourself. When you order it, you'll need to tell the person you order it from it's a 21' patio awning.
The Reader's Digest version of the installation instructions are:
Take loose the rear rafter arm, and unwind the arm. It has a spring with lots of tension, be very careful. Drill out the rivets holding the old fabric to the roller tube, unscrew the center cover slat, and slide th old fabric off the tube. Installation is the reverse of removal, and the spring gets wound one turn per foot of awning.
Old 09-15-2011, 09:23 PM   #3
1981 31' Excella II
Are you talkin about ordering the raw material and making one or getting one already hemed and seamed? I assume you would need to have them make one that is the length of the roller tube and whatever the span is. I guess there could be a little more material on the roller than you will actually end up using?
Perry
Old 09-15-2011, 09:27 PM   #4
Well Preserved
1993 21' Sovereign
Perry
You order the material premade, you slide it onto the roller and rivet it in place. The only part you end up not "using" is the part that is a loop at the roller end that the roller goes through.
Old 05-27-2012, 02:25 PM   #5
CampUnger's Avatar
Wabash , Indiana
I priced an awning co in Ft Wayne, IN that said $350ish-$550ish (depends on the type of fabric chosen) for them to make it plus another $120-$150 for them to install. They use the sunbrella fabric.
we have a 31' AS with a 21' awning
CampUnger is offline   Reply With Quote
Old 05-27-2012, 03:55 PM   #6
awning
The currect published price for Zip Dee awning fabric, for standard to them colors, is $36.00 per running foot.
Awning Advise Please 69trotter Awnings 10 08-20-2011 06:17 PM
carefree awning fabric width johnhh Awnings 0 07-30-2011 10:16 AM
Using your awning sbcohn On The Road... 29 06-14-2011 06:14 PM
Awning Hooks Kathleenh 1997 - 2004 Bambi 3 03-14-2011 12:38 PM
