Old 03-07-2011, 03:37 PM   #1
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
How important is the alluminum guard
I have priced an A&E awning for my AS. Does everyone have the alluminum guard? The price difference is considerable. My SOB did'nt have it but they do look good. Does anyone have any thoughts on this? I also may have the option to buy a used zip dee off a 2006 for a little less than a new A&E without guard, but it would need cut down. Will it fit a 69' ?
Get right or get left, and have a blessed day !
TAC OK-5
lahrfarm is offline   Reply With Quote
Old 03-07-2011, 04:33 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
You will like the Zip Dee better. The uncovered awning looks bad and exposes the fabric to the elements. I do have a 9000 A&E which has a metal cover...pretty nice. If you can get a Zip Dee cheaper than an A&E....thats a deal. But, now it gets stickey with cutting and modifying. Thats your choice. Check with Zip Dee on that and the model arms you are looking at.
Old 03-07-2011, 04:43 PM   #3
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
I believe the Zip Dee arms changed with the 1996 wide bodies. I have had both and would VERY HIGHLY recommend the Zip Dee, they are better in all comparisons. Zip Dee is much more customer friendly! You may spend more, but you'll never regret it! I'd check with Zip Dee before considering the used unit from a 2006, just call them!
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 03-07-2011, 05:33 PM   #4
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Anyone know if you can purchase an aluminum cover aftermarket?
I have an older A&E 8000 with no cover - it's currently in good shape and I would buy a cover if it were somehow adaptable to what I have.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 03-07-2011, 06:09 PM   #5
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
On my previous trailer I had an A&E vinyl awning. Typically the fabric awnings have the metal covers while the vinyl type don't. After several years a vinyl awning, the part of the awning that is exposed to sunlight when rolled up, will eventually start cracking allowing leakage (ours did) and will eventually tear. I would think the metal cover would provide better protection. Additionally the metal awning looks much better when rolled up.
au_ee is offline   Reply With Quote
Old 03-11-2011, 02:04 PM   #6
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
I talked to Zip Dee and the lady said the 2006 zipdee will not fit my 69' ! I'm not sure I can afford a new zipdee so I may do an A&E.
TAC OK-5
aluminum value scrap on 27 foot 386kustoms Trailer Values 8 02-10-2011 11:57 AM
Purpose of rear rock guard? Maryw164 Rock Guards, Segment & Window Protectors 20 01-20-2011 03:56 PM
December 2010 Photo Contest RangerJay Photography 64 01-02-2011 07:51 PM
