Old 01-23-2009, 01:03 PM   #1
coffeydelsol's Avatar
1986 25' Sovereign
Ocala , Florida
How do the awnings function - 86 Sovereign
We have a deposit on an 86 Soverign that we are supposed to inspect tomorrow. The dealership is really selling the as is becaus of the age of the unit. However, my sales person went through the unit and says everything works but she could not get the awning out and she asked for one of the guys to help and they still could not figure it out. Is there some kind of process that we should know about so we can see if it works when we get there tomorrow.
coffeydelsol is offline   Reply With Quote
Old 01-23-2009, 01:18 PM   #2
SteveH's Avatar
Common Sense , Texas
It's hard to explain in words, but generally speaking, the awning rolls out from the top, then arms are extended at each end to hold the awning out, and then the lower arms slip out and go longer to elevate the rolled out awning.
It really is easier than it sounds, if all the mechanism is working. Best done be two people.
Old 01-23-2009, 01:35 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
This should help you out: Awnings By ZipDee
or maybe this one: Awnings By ZipDee
depending if the awning has a z-lock or travel lock or both.
Richard
azflycaster is online now   Reply With Quote
Old 01-23-2009, 01:47 PM   #4
1986 25' Sovereign
Ocala , Florida
Great links - Thanks- I am hoping it works!
Old 01-23-2009, 01:52 PM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
They are really quite easy to open and close. I can set mine up in a minute or two.
Richard
Old 01-23-2009, 02:26 PM   #6
345bill's Avatar
Las Vegas , Nevada
As Coffeydelsol mentioned these are great links. I know they will help me understand our awnings on the 345. THANKS for posting Richard !!.
345bill is offline   Reply With Quote
Old 01-23-2009, 03:08 PM   #7
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Coffeydelsol,
We have a 1987 and the opening of the Zip-Dee awning has one more step than the ones posted on the Internet. There is a little lever on the right hand side of the awning roller assembly. The lever has a little loop at the end of it that the awning pull down pole fits into. If the lever is in the up position the awning roller is locked. In order to lower the awning, use the pole to pull the little lever to the down position and then you can deploy / extend the awning. Once it is down you can put the little lever in the up position and that will prevent the awning from retracting while you mess with and tension the support poles.
By the way welcome to the forums and good luck with your inspection.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 01-23-2009, 03:20 PM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
I believe you are refering to the z-lock. It is step 1 in the second link. The newer awnings do not have them, but older ones do.
Richard
Old 01-23-2009, 03:30 PM   #9
DEITZ645's Avatar
Richard,
The "Z" lock is on our '06 and it is towards the back of the trailer on the left site of the awning roller. The '87 does not have the "Z" lock. The little lever that I am speaking of is on the extreme right hand side of the awning roller. And of course I do not have any pictures of it. When I go down the orchard tomorrow I will take some photos of the "Z" lock on the '06 and the lever on the '87 and post here.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 01-24-2009, 07:01 AM   #10
DEITZ645's Avatar
OK, here are the pictures I promised. I risked life and limb going out in the frozen tundra to get these pictures.
The first four pictures are from the '87 and the last one is from the '06
This is the "Z" lock lever in the up and locked position. With the "Z" lock lever in this position the awning will not deploy or retract.
This is the "Z" lock lever in the down and unlocked position. In this position the awning roller will deploy and retract.
This is the wheel clamp in the closed and locked position.
This is the clamp open.
This is the travel latch that is only on the '06.
I hope the pictures help.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 01-24-2009, 07:15 AM   #11
2002 25' Safari
Dewey , Arizona
Images: 62
Nice pictures from the frozen tundra. I think we are getting our terms a little confused here. The first picture is what ZipDee refers to as the z-lock. Awnings By ZipDee
The part in the last picture is called the travel latch. Awnings By ZipDee
My awning only has a travel latch...
Richard
Old 01-24-2009, 07:21 AM   #12
DEITZ645's Avatar
Richard,
You are correct. I was confused. I have edited my post to reflect the proper terminology. I did not see the "Z" lock page in your last post.
Our '06 only has the travel latch and the '87 only has the "Z" lock...Go figure. Why do they switch back and forth???
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 01-26-2009, 05:30 PM   #13
1986 25' Sovereign
Ocala , Florida
Well thanks to all your help and comments we were able to deploy the awning on the unit and it is in great shape - both of them. We ending purchasing the unit and are thrilled with it. Thanks for all your help, by the way - this unit only had the travel locks (wheel things) not other locks.
Old 01-26-2009, 05:37 PM   #14
2002 25' Safari
Dewey , Arizona
Images: 62
Congratulations on the purchase, nice looking trailer.
Richard
Search function broke? Goldilocks Forum Admin, News and Member Account Info 5 05-09-2008 07:00 AM
Ignore Function doorgunner Forum Admin, News and Member Account Info 56 01-31-2008 08:56 PM
Search function? markdoane Forum Admin, News and Member Account Info 6 09-13-2007 11:35 PM
univolt function mlmarch Classic Motorhomes 12 04-13-2007 01:39 PM
What is this function? bkpine Fresh Water Systems 2 08-15-2002 04:01 PM
