Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 10-04-2003, 04:56 AM   #1
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Ground bracket solution for awning
I saw an alternative awning bracket solution at a recent rally and want to find out more information on it. The bracket is driven into the ground and then the awning arm is detached from the trailer and attached into the grounded bracket. The immediate pro I can see to this solution is it eliminates the "head-banging" problem if used on the awning arm next to the door. I have lots of questions about this solution:
1. How does it stand up to wind compared to being attached to the trailer?
2. Does it keep the awning taut so rain water doesn't pool on the awning?
3. Can it be purchased online?
4. Has anyone made one? It looks easy enough to put together!
5. Has anyone found any downsides to this solution?
Name:	awning bracket ground solution.jpg
yukionna is offline   Reply With Quote
Old 10-04-2003, 05:22 AM   #2
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I've seen this done on an awning from a SOB unit but they also had nylon straps that went from the awning to the ground with a screw-in device as extra precaution.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-04-2003, 07:06 AM   #3
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
the whole thing?
yukionna,
do you have a photo of whole awning when using the plates?
it would be interesting to see what angle if any, the arms are at. and any additonal tie downs used.
john
you call them ferrets, i call them weasels.
john hd is online now   Reply With Quote
Old 10-05-2003, 09:09 AM   #4
yukionna
yukionna's Avatar
Images: 18
No, I don't have a full awning photo -- I only took a photo of the bracket!
19' Bambi ground clearance/"lifting" Glenn Hansen General Repair Forum 13 09-16-2007 07:11 AM
CB Antenna Bracket Mounts Dwight Phone, CB & Ham Radio 1 01-26-2004 02:07 PM
Zip Dee Support Bracket LTD93 Awnings 2 12-12-2003 07:51 AM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
