Foot bases for Zip Dee Carport set-up?
HI....
I have a Zip Dee awning on a 2007 19" Bambi. I hate stepping out the door and trying to take a left turn... running into the diagonal awning arms. Or 'clotheslining' myself in the neck as I try to walk in from the side.
Where can i get 'foot base plates' so I can swing the arms down into a 'carport' style set-up? I would need to detach the main awning arms from the trailer (replace the bolts with a quick-release 'pin' of some sort and swing them out into a vertical position. I would be willing to use support ropes if needed. Seems like it would be much easier to walk in, under, around and through. Has anyone else done this? Seems like many folks would be doing it...
Phantom
