Old 05-27-2011, 07:38 AM   #1
1972 27' Overlander
Rockford , Michigan
Fix original awning
The spring mechanism in our main side awning is broke; we have a '72 Overlander. Has anyone ever fixed one before? The airstream dealer near us thought it was possible.
MelB is offline   Reply With Quote
Old 05-27-2011, 08:22 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If the awning is original it is probably an A&E. New parts are not available. I would check with RV repair shops about a used spring. If you try messing with the spring be careful it is an arm breaker. Because parts are in very short supply for A&E I put on a Zipdee.
Old 05-27-2011, 08:59 AM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
My '72 Overlander had a ZipDee, so yours might too. If so, Go to their website and/or give them a call- they have a great customer service department, and can supply the necessary parts and how-to-install info you need. Great awnings!
tphan is offline   Reply With Quote
Old 05-27-2011, 09:06 AM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
Unless it was a custom order Zipdees were not standard in 72. Zipdee certainly was around in 72 and does have a very classic and distinctive look. Ditto on great customer service. It seems like other awning manufacturers don't want to talk directly to customers, referring them to dealers.
Old 05-28-2011, 07:19 PM   #5
1972 27' Overlander
Rockford , Michigan
fix awning
thanks for your help. We'll let you know if it is fixable.
How do you know who made your awning? neal Awnings 4 04-03-2011 12:23 PM
Awning Hooks Kathleenh 1997 - 2004 Bambi 3 03-14-2011 11:38 AM
Original External Water Tank fill cap for 69 commander31 Fresh Water Systems 1 02-07-2011 01:38 PM
