Old 01-03-2005, 02:14 PM   #1
Faulkner awning help.
Hello support group. I recently (4mo) purchased a 1975 25' Tradewind that came equipped with a Faulkner awning that has a broken end cap on the roller tube and a broken spring. I learned through my search that Faulkner is no longer around and I am out of luck. Does anyone know where I might find parts that would work for this awning? Maybe I can modify. Everything else is fine. Hopefully the pictures attached will help. Thanks in advance for any input.
bob
Name:	Broken end cap.JPG
ID:	9969   Click image for larger version
Name:	Broken Spring.JPG
Crazyland is offline   Reply With Quote
Old 01-03-2005, 03:08 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Bob!
bob
I suspect that you may experience what I did with my '64 Overlander with its original A & E Travel Awn 5000. Even with roller tube parts available, it was a loosing proposition to keep up with the inevitable worn and broken parts. I finally gave up on the original awning after three years and close to 80% of the cost of a new Zip Dee awning invested in a still constantly broken obsolete awning.
Your photos suggest that the roller tube is very comparable to that found on the A & E Travel Awn 5000. While it might be possible to adapt a properly sized A & E roller-tube to your Faulkner awning arms, my concern would be safety of the modifications due the potential for unexpected problems with the spring-loaded mechanism if the mounting is other than the original factory design.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 08-19-2009, 09:41 PM   #3
casa grande , Arizona
Did you have any luck repairing this awning? I have the same problem. Thanks for any info.
ryde2rope is offline   Reply With Quote
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Awning Heads Up!!! JaceBeck 1999 Safari 39 04-25-2006 05:31 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Awning gwrimmer General Motorhome Topics 1 11-07-2002 11:59 AM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
