06-15-2014, 05:15 PM
1976 Argosy 26
Simsbury
, Connecticut
extension arms
Hello,
I have a 1976 26' Argosy and my extension arms are frozen shut. Is there any way to free them or do I need to replace them. The rest of the awning is in great shape. I already tried spraying liquid wrench between the arms for a week and trying to separate them with a come along to no avail.
Thanks, Gary.
06-15-2014, 06:41 PM
1970 27' Overlander
1970 21' Globetrotter
Hamilton
, Montana
P B Blaster at an auto parts store or CorrosionX spray might be a bit better than liquid wrench.
06-15-2014, 06:46 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Hopefully its not a case where the arm is bent and shoved in the square tube, that's nearly impossible to separate.
Are you certain the locking.g pins are free and allowing the 2 pieces to move independent of one another?
06-15-2014, 06:55 PM
1976 Argosy 26
Simsbury
, Connecticut
The locking pins seem to be working fine and the arms are not bent. When in spray the liquid wrench in there it does not want to seep in. It looks like they may be fused together.
06-15-2014, 07:04 PM
Overland Adventurer
2009 34' Panamerica
Telluride
If you can't get them apart, how can you know they aren't bent?
Same question goes with any corrosion?
You might be able to remove the claw end components and drift it out with a little persuasion. Just don't get anything else stuck in there!
06-15-2014, 07:24 PM
1976 Argosy 26
Simsbury
, Connecticut
they are definitely not bent and i put a lot of force on it with the come along. I think they might be fused together.
06-15-2014, 11:15 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
on my former trailer one arm had bent and been forced together to stow the awning. over time in addition to the friction an aluminum growth developed in there that made it difficult to separate. i won't recommend my method repair but if i had it with me i would have used a slide hammer. a lubricant for aluminum should help.
Ricky
06-16-2014, 05:42 AM
2008 27' International FB
Venice
I would suggest an little persuasion with a heat gun or a hair dryer to the outer arm. If possible try this with the arm off the trailer and in a vise, protecting the surface with rubber or cardboard to prevent damaging the surface. When heated try tapping one end with a hammer with a piece of wood on the metal, very lightly at first just to make movement, then insert some lubricate wait a while for it to work and continue on. Patience is the key. Good luck.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
06-16-2014, 01:03 PM
Overland Adventurer
2009 34' Panamerica
Telluride
My money is still on bent and stuck !
06-16-2014, 01:58 PM
1967 22' Safari
MILAN
Awning type
Gary, What brand awning is it? When was the last time you had it opened up? Are there any locking knobs thru the outer slider arms that might be holding the inner slide in the locked/closed/stored position? Just a few possibilities. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
06-16-2014, 02:54 PM
1976 Argosy 26
Simsbury
, Connecticut
It is a Zip Dee and I have never opened it as it was stuck when I got the unit three years ago. There is no other locking mechanism other than the release knob at the top that I can see. I'll to take some pictures in the next few days if that would help.
06-16-2014, 02:55 PM
Overland Adventurer
2009 34' Panamerica
Telluride
You have the travel latch unlocked, right?
06-16-2014, 03:09 PM
1976 Argosy 26
Simsbury
, Connecticut
Yes, I can unravel the awning all the way, set the rafter arm and then cannot extend the awning in the up position.
06-16-2014, 03:18 PM
Overland Adventurer
2009 34' Panamerica
Telluride
extension arms
Bent, bound, stuck, unless you have been through a caustic truck wash and the stuff didn't drain out.
06-16-2014, 04:19 PM
1967 22' Safari
MILAN
Help!
Pictures would help somewhat. Make sure you get clear close-ups of the awning arms and the slide tracks. If you are able to roll the awning out then it would not be an issue with the travel lock as this is meant to keep the material/roller from unfurling during travel. Some arms have slide locks that keep the arms together in the stowed/lowered position. They used a black or white knob on a machine screw that ran thru the upper arms and locked the inner slide and had to be loosened to deploy the arms to their extended position. Then you tightened the screw/knob to lock the arms in the extended position. Check the inner and outer sides of your arms to see if there may have been these lock screws that might be broken off in the nut cert. This would easily cause the stuck issue you describe. Or if actually stuck one inside the other then you could remove the bottom bolt that attaches the arm to the bottom brackets one at a time and try driving the inner slide out of the outer slide arm. Failing that you could always try a call to ZipDee and ask for assistance with your awning issue. I understand they can be very helpful and may even be able to furnish you with a manual. Ed
