Old 10-04-2012, 08:26 PM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Exploding Awning Springs
Camping this weekend. Pulled the streetside awning out. It appears to be the newest of the three.
About an hour after pulling in I'm in the trailer setting up, hear a loud boom and the camper shook. It's a little windy and the door wasn't set so I blamed it on that slamming open. Cussed myself and went on.
Just went around the back to find the awning strap hanging free. Clearly the spring broke. I'm two hours from anywhere with a 20 foot awning that won't close on it's own. I can roll it up by hand but it won't stay fully closed. Afraid it will open on the way home and rip the brackets out of the side of the trailer.
Any suggestions - I don't see anything to strap it off to..
Old 10-04-2012, 08:59 PM   #2
RoadHungry's Avatar
2004 28' Safari S/O
Tifton , Georgia
Zip ties? They have saved me a few times. Can't really say too much without seeing it. Good luck.
RoadHungry is offline   Reply With Quote
Old 10-04-2012, 09:12 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
It's a Zip Dee so it has the aluminum housing that folds around it. No way to get a zip tie or strap around the body of the awning.
Old 10-04-2012, 09:12 PM   #4
1977 Argosy 24
Milltown , Wisconsin
Go find some rachet straps. Get some rope and use the rope with a loupe in each end to go around the entire trailer and use the rachet straps to tighten down the whole thing, pinning the awning to the side of the trailer.
ventport is offline   Reply With Quote
Old 10-04-2012, 09:41 PM   #5
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Good idea, vent port. Or have zipped rush a spring to where ou are. We replaced ours, it took about 45 minutes including reading and rereading the directions and luring the arms etc.
Skatiero is offline   Reply With Quote
Old 10-04-2012, 09:42 PM   #6
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Sorry, autocorrect! Zipdee, not zipped, and lubing the arms, not luring. Sheez!
Old 10-04-2012, 09:44 PM   #7
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
How far are you from Jackson center? Maybe you can o pick a spring up. Or have one delivered from there.
Old 10-04-2012, 10:03 PM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
It'd take about 4 hours to Jackson Center from here. What the heck do you do to replace a spring? Drill the rivets out of one end and pull the spring/core out? Then put the new one in, wind it and reset the arm bolts.
Old 10-05-2012, 04:26 AM   #9
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Ganglin View Post
.... What the heck do you do to replace a spring? ...
My Overlander's Carefree awning has two springs - one at either side of the barrel. To get at either, the end cap, as you guessed, would have to be removed. That would be tough with the awning installed.
I'd call Jackson Center first to see if they stock new springs for Zip-Dee; my bet is "no".
A spring breaking on my Carefree of Colorado awning would NOT prevent the awning from latching into place once rolled up. Rolling up would be accomplished by hand by standing on a picnic table. Are you sure you are truly hosed without a new spring?
Good luck,
Tom
Old 10-05-2012, 05:11 AM   #10
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
did you try rewinding the spring? I would probably try that before ordering a new one....it's at least worth a shot. I think you wind 7 times plus one time for each foot of your awning (I did mine this summer) It takes two people....one holding the awning while you have the arm off & wind.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 10-05-2012, 05:19 AM   #11
1981 31' Excella II
New Market , Alabama
My awning has a locking mechanism so once it is rolled up it can't unroll till you move the little lever out. It also has locking clamps that hold it in position. DO you have either of these locking mechanisms?
Perry
Old 10-05-2012, 06:48 AM   #12
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I have 3 awnings. The main awning has locks - rear wondow and streetside awnings are held in place only by the coil strength of the springs. The one that broke extends about 30 inches and the pull strap attaches to a hook on the side of the trailer.
Old 10-05-2012, 07:16 AM   #13
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Perry
They are called Z Locks. I think they are only available for the main awning. I use em. Good just in case.
Lumatic is online now   Reply With Quote
Old 10-05-2012, 07:51 AM   #14
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Airstream has no springs. Zip Dee says dealers have no springs since they ""stiffen" if they sit around. They recommended trying to rewind it as Becky mentioned. It takes two people but they said try it with 3 or 4 turns by myself and that will tell me if it's going to wind. If it does hopefully a helpful camper will "volunteer". If no takers, and it will wind, I'll try it by staking it out with the strap.
All I wanted to do is veg out from work this weekend - oh well...
New Awning Fabric Installed, Thanks To You! Max Well Awnings 12 04-23-2012 07:15 PM
Do you polish your awning???? robwok Cleaning, Stripping & Polishing 6 02-11-2012 06:12 PM
carefree awning fabric width johnhh Awnings 0 07-30-2011 09:16 AM
How do you know who made your awning? neal Awnings 4 04-03-2011 12:23 PM
SoCal dilemma: Desert Hot Springs, Borrego Springs or Temecula? Stella On The Road... 5 03-13-2011 04:59 PM
