Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 04-10-2003, 04:52 PM   #1
Question E Z awning
Anyone out there know any thing about awnings? Mine is a 16 foot E Z awn-or at least that is all that is still legible on the label. I have a 1971 25ft Tradewind. I need a source for new canvas and some other small parts. You should have seen the size of the bee's nest in it! The awning had been rolled up about 4 years and it is wasted.
joecj76 is offline   Reply With Quote
Old 04-10-2003, 05:50 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
E Z awning
I would venture a guess that the awning was likely manufactured by A & E - - during the era of your coach, A & E, Carefree of Colorado, and Zip Dee would have been three of the more common brands of awnings. I mention A & E because of the "awn" in the model name. My '64 Overlander originally had an A & E Travel Awn 5000, and it seems A & E had the word "awn" somewhere in the model names of their awnings at that time. Another means of identification (not positive as the Carefree of Colorado is quite similar) would be the awning arms - - the A & E arms are rectangular in shape with the lower section being larger with the upper (smaller portion) sliding inside of the lower - - a pair of buttons is found on either side of each arm to allow the arm to be extended/retracted. Another means of identification is the side extension support rod that rises above the awning top when the awning is fully extended - - it produces a very characteristic "arch" above the awning (again, the Carefree of Colorado can be similar in some models).
While I can't be positive, I do believe that you most probably have an A & E product. I found A & E (Dometic) to be quite responsive when I had questions a few years ago about my Travel Awn. You might contact them to see if the E Z Awn is one of their products. If it is an A & E most all parts are still available with the exceptions of the arms themselves. I was told that the arms haven't been available for nearly a decade.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 04-10-2003, 06:19 PM   #3
Thanks for your help, Kevin. I knew someone out there was alot smarter than me!
Joe
Old 04-10-2003, 08:32 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
try these folks,
http://www.canvasreplacements.com/
john
Old 04-11-2003, 10:04 AM   #5
Roundhead's Avatar
My awning is likely shot, too.
It's from Carefree of Colorado. Is this company still around?
Recommendations?
Roundhead is offline   Reply With Quote
Old 04-11-2003, 10:07 AM   #6
Roundhead's Avatar
Never mind!
Found their website:
http://www.carefreeofcolorado.com/
Awning Heads Up!!! JaceBeck 1997 - 1999 Safari 39 04-25-2006 05:31 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Replacing Awning Arms beachmpk Awnings 7 10-05-2004 01:28 PM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
