Old 05-31-2004, 11:01 AM   #1
markus's Avatar
e-z awning
e-z awn
The awning on my AS is shot, on the vertical arm there is
a lock pin to keep it in place, on it is stamped "e-z awn"
are they still in business?
I know I can replace the awning itself but was wondering bout misc. hardware
parts etc.?
markus
markus is offline   Reply With Quote
Old 05-31-2004, 04:16 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
e-z awning
Greetings Markus!
Originally Posted by markus
e-z awn
parts etc.?
markus
I am not absolutely certain, but believe that your awning was made by A & E. During the 1960s and 1970s, A & E actively supplied awnings for Airstreams. A & E is still around, and is a part of Dometic. If your awning does turn out to be an A & E product, I suspect that you will find the same thing that I learned about my A & E Travel Awn 5000 - - the roller tube and fabric is still available, but the arms themsleves as well as related hardware is no longer available. I spent nearly the cost of a new ZipDee awning in trying to restore the Tavel Awn 5000 on my Overlander to operation - - finally gave up and purchased a set of ZipDees for the Overlander. You can contact A & E through their website at:
Dometic/ A & E RV Awnings
E-Mailing customer support was how I learned more about my Travel-Awn 5000 - - if you E-Mail A & E, you will at least be able to learn whether your awing is/was one of their products.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Replacing Awning Arms beachmpk Awnings 7 10-05-2004 01:28 PM
1965 Caravel Awning robandzoe Awnings 8 05-26-2004 07:46 AM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
