Old 07-09-2007, 02:41 PM   #1
2005 34' Classic
Richmond , Virginia
Door tearing awning?
Hey folks,
I just opened up my awning for the first time and found out that I have to raise the awning awful high so the door wont drag the awning. Is this normal? The door is rounded so I doubt it could get torn but wouldnt it still wear the awning after a while? I stopped raising at the fourth hole. are there more holes?
By the way I had a broken rafter claw and Zip Dee is sending me one for free! Those guys seem to really stand behind thier product.
Resorts is offline   Reply With Quote
Old 07-09-2007, 02:44 PM   #2
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Our awning has to the in the highest position in order for the door not to rub. I thought--for about 1 second -- about putting a roller on the top of the door BUT the thought of a hole in our trailer stopped me.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 07-09-2007, 02:45 PM   #3
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Greetings-
Welcome to the forums! I know on the older AS there was a problem with some awnings and doors. There is a roller that can be attached to the upper section of the door to help push the awning up as the door opens but I thought that was on the older units only. Perhaps someone else can chime in. As for the Zip-Dee arm breaking, it is a common problem with these units. Yes, they will keep sending you new ones everytime one breaks but that doesn't help you when you are in the middle of a three week trip. I had ordered and paid for a spare just in case, and keep in my toolbox.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 07-09-2007, 02:46 PM   #4
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Same here with the Safari 25 ft. I have to have it at it's highest point.
R/
Safari-Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 07-09-2007, 02:54 PM   #5
2005 34' Classic
Richmond , Virginia
Thanksfor the info.
Is the fourth hole the last one? I can see it now, ....Im standing there on the ladder (Im short) pushing up on it and the inner pole pops out and im hollerin for someone to come by an slip it back in for me.
Old 07-09-2007, 02:54 PM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The four hole is it. If you go much past it the support rod will separate (not irrepairable, but not good). Mine also needs to be in fourth hole for the door to clear. I drop the end of the awning opposite the door to third hole when rain is coming. This is necessary for rain water to drain properly. If you don't do this large amounts of water will sit in the awning.
SuEllyn & Brian McCabe
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Awning Heads Up!!! JaceBeck 1999 Safari 39 04-25-2006 05:31 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Awning gwrimmer General Motorhome Topics 1 11-07-2002 11:59 AM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
