Old 03-22-2015, 09:28 AM   #1
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Do Zip Dee Awning Seams Leak
We've had an AS for about 2-1/2 years, and I think this may be the first time I've left the awning out during a long rain. I'm usually too nervous about wind and close it. We had a light rain most of the night and morning with no wind, so I left it open. There are small droplets running down each seam in the awning. I assume this is normal and/or is there a seam sealer you can use?
Landrum is offline   Reply With Quote
Old 03-22-2015, 09:34 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Quick fix, when the awning is dry, spray the seams— both sides— with Scotchgard Fabric Protector. Should help water bead up and run off rather than soaking through.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-22-2015, 09:38 AM   #3
1994 30' Excella
Mississauga , Ontario
check with Sunbrella. They manufacture the fabric. I believe they sell or recommend a product for their fabric.
Al
Al and Jean
TAC ON-3
Old 03-22-2015, 09:42 AM   #4
Landrum's Avatar
Good ideas. Thanks
Old 03-22-2015, 10:31 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
According to the Sunbrella website you should use an acrylic seam sealer. There are several good ones on the market. Plastiseam and Sil-seam are two that I have used with good results. Check your local boating supply store.
Aaron
WBCCI #XXXX AIR #2495
Old 03-22-2015, 10:39 AM   #6
aftermath's Avatar
Spokane , Washington
I would check with the factory before I did anything to the awning. If this is a brand new awning it just might have to be "cured" like older canvas tents and awnings. Once the fabric gets wet, for the first time, it swells a bit and the stitching seals itself. This might or not be the case with yours so checking with the manufacturer is the way to go.
Having had an SOB with one of their vinyl type of awning I continue to be amazed at the quality of the zip dee. Mine is going on 9 years old and it doesn't leak a drop, anywhere. When I brought it home after buying it slightly used, I opened it up and hosed it down to wet it completely. It dried in the sun and that has been it save for an occasional light cleaning. Works and looks great.
aftermath is offline   Reply With Quote
Old 03-22-2015, 10:40 AM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have been using 303 Fabric Guard Water Repellent on Sunbrella and tent fabrics for years. Says on the bottle that it is recommended by Sunbrella. http://www.amazon.com/303-Products-3...+fabrics+guard
MICHAEL
Old 03-22-2015, 10:41 AM   #8
ckottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I thought if the awning is left fully open in lengthy rain it could fill up like a bathtub, and the weight would be more than the support arms could hold. Or would it run off, we have never tried it.
cheryl
ckottum is offline   Reply With Quote
Old 03-22-2015, 10:46 AM   #9
AWCHIEF's Avatar
Images: 33
Drop one side and give the water someplace to go. Three buttons on one side and four on the other works well for me.
MICHAEL
Old 03-22-2015, 11:18 AM   #10
Landrum's Avatar
Our AS is just under a year old, but this may the first time it's gotten wet. So I may spray it down at home and see if the seams in fact sealed up.
Old 03-22-2015, 11:20 AM   #11
AWCHIEF's Avatar
Images: 33
Remember the old canvas tents? They were water proof until you touched them and then they leaked like a sieve.
MICHAEL
Old 03-22-2015, 12:11 PM   #12
2014 27' Flying Cloud
Stowe , Vermont
Check with your dealer first for recommendations (if it's not written in your owner's manual). Be sure to keep one side higher than the other, so that the water will run off the low side without pooling.
VT Wanderer is offline   Reply With Quote
Old 03-22-2015, 12:49 PM   #13
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Sunbrella is not waterproof. It will repel water for some time and then it will leak everywhere. After drying out, it will repel water again. I know this well from my boating days. There is a Sunbrella fabric with a waterproof backing but our awnings are regular Sunbrella. You do need keep one end of the awning lower in the rain, but there is no point in leaving it deployed for an extended time while it is raining.
Larry
lsbrodsky is offline   Reply With Quote
Old 03-22-2015, 12:52 PM   #14
Some hints I've learned from using my awning in wet weather: along the Gulf Coast is there such a thing as dry weather?
When you lower one end, lower the end that most faces into the wind. That will increase the wind resistance slightly, because the wind will try to push it down rather than lifting it (except that wind gusts always want to lift the awning).
If there's no wind to speak of, lower the end that's farthest from your entrance door to control puddling where you'll walk.
If you use a waterproof— or better, porous— patio mat, position the mat so the runoff from the awning hits the mat, not the bare ground. Runoff is less likely to splash mud that way.
Increase the runoff rate by lowering both ends by one notch, still keeping one end a notch higher than the other. Water runs off better from a steeper slope. And again it also improves wind resistance slightly.
WBCCI #1105
TAC LA-4
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip-Dee Awning Repairs ViewRVs Awnings 3 08-31-2006 06:28 PM
Zip Dee awning problem DbackFan Awnings 12 04-06-2003 01:47 PM
