Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 06-17-2020, 08:58 AM   #61
1978 28' Ambassador
Gainesville , Georgia
Looking for Carefree endcaps and spring assembly.
Do you still have parts?
I am NE of Atlanta and would love to see what you have. I will be passing through Tennessee June 28.
Peggy Egan
Peggyegan is offline   Reply With Quote
Old 06-18-2020, 04:28 AM   #62
1960 22' Safari
Johnson City , Tennessee
Peggy Egan
I still have some of the awning swig arm parts. I’ll dig them out and see. I’ve sold everything else.
teilhet is offline   Reply With Quote
Old 06-18-2020, 07:50 PM   #63
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
Are these Carefree parts?Click image for larger version
montanablue is offline   Reply With Quote
Old 06-18-2020, 10:52 PM   #64
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
Those are Vintage Carefree parts.
Yes, those are Vintage Carefree awning parts.
Top and center: the 3 pieces with the rectangular holes are sliding locks that fit inside the main arms. One has a post and ther other 2 have posts with them but they are not installed. The post goes at the top and points toward the trailer and that is what you hold on to slide it up and down. These slide down over the travel hook when the arm is closed to lock it in place.
Top right: is a main arm lower support that the arm pivots on and the angle brace fits behind when it is disconnected from the arm and stowed for travel.
Right side: 2 pieces are the stops that go on the roof over the awning channel for the tube to rest against.
Bottom piece I don't recognize.
Lower left piece I don't recognize.
Left side: those 2 pieces are the hook part of the travel hook.
Upper right: Are the 2 U shaped pieces the travel hooks fit into. These bolt to the body half way up the sides and the travel hook slides into them and can be adjusted in and out to make the arms vertical when stowed. A bolt goes thru both pieces to lock them together.
Past President, Vintage Airstream Club, WBCCI # 7291
1977 Argosy 28 Center Bath
(CA made) and 2015 Ford F250 6.7 diesel. Used to own 1978 Argosy Minuet 6.0 and 2013 Toyota Tundra
rvb is offline   Reply With Quote
Old 06-19-2020, 05:30 AM   #65
Kevin245's Avatar
The lower left component is the center support arm bracket that mounts to the trailer body.
William C. Swinney
Old 06-19-2020, 05:51 AM   #66
1997 25' Safari
1973 25' Tradewind
Thanks, I thought they were Carefree.
Curved arms for a Carefree Awning BN3N4 Tscheese Airstream Classifieds 0 08-25-2016 03:21 PM
Vintage Carefree awning with curved arms bredlo Airstream Classifieds 0 07-03-2014 05:32 PM
Carefree awning missing parts ??? arcamedies Awnings 2 02-09-2010 10:31 AM
Carefree window awning parts WineStream Windows & Screens 0 03-06-2009 06:47 PM
FREE Carefree Awning Parts - Austin, TX qjktx Awnings 2 10-03-2006 07:30 PM
