Old 05-18-2009, 07:28 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Cleaning Zipdees
I have a Zipdee with a canvas rag that I am cutting down to install on my Tradewind. I have the canvas off and am thinking it's a good time to clean the canvas. The canvas still looks like it has a lot of life left. Suggestions for cleaning?
Also I need a few Zipdee arm parts if anyone has any to sell.
Old 05-18-2009, 07:39 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Lumatic,
Take a look at the eighth paragraph of this link...
Awnings By ZipDee
And this link...
Awnings By ZipDee
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 05-18-2009, 10:22 AM   #3
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
We use a solution of Woolite and water. Get the fabric wet, Rub soap in with the soft bristled brush, Roll awning up for the length of a few beers, open and rinse with lots of water. I rinse top first then bottom and then top again. We do this every spring, and just a good rinse and brush in the fall ( to get the loose dirt off before winter). This is the method my grandfather used and the awning is 19 years old and looks brand new.
Mike
memgrove2000 is offline   Reply With Quote
Old 05-18-2009, 05:30 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
What do you think about a rinse with a pressure washer?
Old 05-18-2009, 07:22 PM   #5
DEITZ645's Avatar
Lumatic,
When we got our '87 the main awning was pretty nasty from not being used. I used my pressure washer with the normal strength nozle and it cleaned up almost as good as new. It took a couple of passes, but it was worth the effort. It has been two years since I pressure washed it an it still looks great and sheds water like it was new. Since then I use the mild soap, soak, brush, roll up, let rolled up for about half an hour, unroll, rinse, and let dry method to keep it clean.
I guess it also depends on the age and strength of the fabric. You might want to start with the gentle nozle if your pressure washer has different settings or nozles.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Cleaning? salvarez Cleaning, Stripping & Polishing 16 04-12-2008 12:40 PM
Cleaning Brad Hunt Cleaning, Stripping & Polishing 6 09-14-2007 03:17 PM
cleaning upholstery Tin Lizzy Upholstery, Blinds, Walls & Interior Finishes 6 04-22-2006 09:44 AM
Cleaning Blinds connie Upholstery, Blinds, Walls & Interior Finishes 1 11-30-2003 08:33 PM
Cleaning, Storage dmac Winterizing, Storage, Carports & Covers 1 10-21-2003 08:23 AM
