Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 03-17-2016, 02:15 PM   #1
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Check the capnuts on your awning supports
I noted today that one of my capnuts was missing, creating a potentially ugly situation. I replaced it and checked the others, all loose. Why AS used capnuts instead of locknuts is beyond me. You buy a car or boat and none of the fasteners ever loosen up, but an Airstream???
Larry
lsbrodsky is offline   Reply With Quote
Old 03-17-2016, 02:20 PM   #2
1999 28' Excella
New Orleans , Louisiana
That happened to us..on a leave inspection I spotted one missing and we used good ol duct tape til we bought more at Out of Doors Mart.
badkat is offline   Reply With Quote
Old 03-17-2016, 02:40 PM   #3
2016 30' Flying Cloud
Oviedo , Florida
Zipdee, not Airstream
Keith
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 03-17-2016, 03:40 PM   #4
lsbrodsky's Avatar
Huh? Does ZipDee reside at the Airstream factory installing the awning and the hardware? I can accept that the inferior design might be ZipDee, but it must have been Airstream that did not fully tighten the fasteners.
Larry
Old 03-17-2016, 03:58 PM   #5
PKI
PKI's Avatar
Walnut Creek , California
May not be that they were not tightened. We have had a couple of cap nuts come off the rock guards. Hope we get less overall movement with the centromatics...or maybe that is just wishful thinking. In any case, checking bolts and nuts for tightness periodically is not a bad idea. Just don't over tighten the little guys. Pat
Old 03-17-2016, 03:59 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Or ZipDee did not provide fasteners that remain tightened.
2019 Ford Expedition Platinum
Old 03-17-2016, 04:00 PM   #7
Wayne&Sam's Avatar
Images: 21
Yes, things bounce and get loose.
Old 03-17-2016, 04:15 PM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
A little loctite goes a long way......
there is no such thing as a fastener that stays tight all on its own!
Old 03-17-2016, 04:23 PM   #9
PKI
PKI's Avatar
Which locktight is "THE ONE" to use? Never used it enough to learn the color code, because most replacement nuts have been the nylocks. Pat
Old 03-17-2016, 04:26 PM   #10
Wayne&Sam's Avatar
Images: 21
I'm a fan of blue.
Old 03-17-2016, 05:44 PM   #11
CRH
1995 25' Excella
xxxxx , xxxxxx
Blue x 2
CRH is offline   Reply With Quote
Old 03-17-2016, 08:24 PM   #12
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale , Arizona
Originally Posted by crh View Post
blue x 2
x 3
cactusjk is offline   Reply With Quote
Old 03-18-2016, 07:35 AM   #13
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Blue is undo-able, Red is permanent
Old 03-18-2016, 08:33 AM   #14
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Blue in this instance.
Red is more permanent and requires application of heat to release.
In a pinch a little drop of superglue can work.
Old 03-18-2016, 08:50 AM   #15
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Blue... matches the AS striping.. =)
Oh.. Red if it heats, vibrates or both... I often have to add some where I want 'extra' grip.. one problem... I have 'twisted' things off while trying to remove a fastener with the red stuff...
Blue.. on most RV/AS metal to metal fastener.. we cannot use on plastic, etc. It would be ideal for the 'caplets'..just put the blue on the screw/bolt threads...jus a 'dab' on the beginning of the threads where the fastener threads on.. it should cover where the 'threads' on regular fastener bolts/screws tighten up.. in other words, if you have a long bolt to run the nut down, put the Loctite where things tighten up.
Example.. on my motorcycles, if I had to run a 'screw' into a place, I would put a drop where the threads made contact.. like halfway down.. this way the screw would clear the part and only make contact at the beginning of the threads.
Same for a nut like a caplet..
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-18-2016, 09:20 AM   #16
lsbrodsky's Avatar
Blue..a very good idea, thanks
Larry
Old 03-18-2016, 09:39 AM   #17
1990 32' Excella
jonesboro , Arkansas
Cap nuts
Here's the deal with cap nuts. If a cap nut is not bottomed out meaning the stud or bolt actually touching the dome of the nut it is tech not tight and can vibrate loose. This was from a guy from fastenal. He also recommended a light drop of picture blue.
joel is offline   Reply With Quote
Old 03-18-2016, 10:58 AM   #18
1976 31' Sovereign
Oswego , Illinois
Loc tite also makes green that works like blue except it is self wicking into threads after installing nuts or screws.
Old 03-18-2016, 11:08 AM   #19
PKI
PKI's Avatar
Got it is. Blue it is - added to the pick up list. Thanks a bunch. Pat
Old 03-18-2016, 05:53 PM   #20
2019 25' Flying Cloud
Greeneville , Tennessee
As an old Harley rider, I have learned over time to love Locktite!
jimfa440 is offline   Reply With Quote
need creative ways to build supports for awning teachndad Awnings 4 07-18-2010 06:45 AM
Awning supports Minnie's Mate Awnings 9 12-06-2008 11:11 AM
Interior Rear Supports?? BornToRock General Interior Topics 0 08-23-2005 10:54 PM
Gas Line Supports Falling Off gklott LP Gas, Piping, Tanks & Regulators 5 06-23-2005 02:42 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
