Old 03-18-2016, 08:50 AM   #15
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Blue... matches the AS striping.. =)
Oh.. Red if it heats, vibrates or both... I often have to add some where I want 'extra' grip.. one problem... I have 'twisted' things off while trying to remove a fastener with the red stuff...
Blue.. on most RV/AS metal to metal fastener.. we cannot use on plastic, etc. It would be ideal for the 'caplets'..just put the blue on the screw/bolt threads...jus a 'dab' on the beginning of the threads where the fastener threads on.. it should cover where the 'threads' on regular fastener bolts/screws tighten up.. in other words, if you have a long bolt to run the nut down, put the Loctite where things tighten up.
Example.. on my motorcycles, if I had to run a 'screw' into a place, I would put a drop where the threads made contact.. like halfway down.. this way the screw would clear the part and only make contact at the beginning of the threads.
Same for a nut like a caplet..
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-18-2016, 09:20 AM   #16
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Blue..a very good idea, thanks
Larry
lsbrodsky is offline   Reply With Quote
Old 03-18-2016, 09:39 AM   #17
1990 32' Excella
jonesboro , Arkansas
Cap nuts
Here's the deal with cap nuts. If a cap nut is not bottomed out meaning the stud or bolt actually touching the dome of the nut it is tech not tight and can vibrate loose. This was from a guy from fastenal. He also recommended a light drop of picture blue.
joel is offline   Reply With Quote
Old 03-18-2016, 10:58 AM   #18
1976 31' Sovereign
Oswego , Illinois
Loc tite also makes green that works like blue except it is self wicking into threads after installing nuts or screws.
Old 03-18-2016, 11:08 AM   #19
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Got it is. Blue it is - added to the pick up list. Thanks a bunch. Pat
Old 03-18-2016, 05:53 PM   #20
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
As an old Harley rider, I have learned over time to love Locktite!
jimfa440 is offline   Reply With Quote
Old 03-18-2016, 06:43 PM   #21
2015 23' Flying Cloud
Livermore , California
Which capnuts do I need to worry about on the awning?
cactusjk is offline   Reply With Quote
Old 03-18-2016, 09:18 PM   #22
2004 22' Safari
Albuquerque , New Mexico
Another Option
Why not a nylon locking nut?
Silver.Sanctuary is offline   Reply With Quote
Old 03-18-2016, 09:50 PM   #23
2007 22' International CCD
Probably a snag hazard if I'm in the vicinity 😞
KE4GNK/AE
Old 03-19-2016, 03:56 AM   #24
lsbrodsky's Avatar
All of the nuts on the support arm ends are capnuts.
Larry
Old 03-19-2016, 04:37 AM   #25
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Locktite is great stuff but I always look for "cause" first....
"Treating the symptom" is a common scenario and we've all been there!
Somebody mentioned Centramatics in an earlier post and I can't help wondering if they are correct. A couple of years ago I read a post here that said Dexter did not balance the drums on these units. I didn't believe them and actually called Dexter to verify the info. They confirmed it! No balancing of the big cast iron drums...
Then I spun a brand new Dwxter drum on a very sensative automotive wheel balancer to see just how badly the drums where out... It was amazing!
I actually balanced my new drums before installing them and then balanced the Michelin tires I installed at that time. I have not had a loose screw in the trailer since! Next time I'd simply install Centramatics...
There, 2 cents please!
Bruce
Bruce B is offline   Reply With Quote
Old 03-19-2016, 04:19 PM   #26
1998 30' Excella 1000
Livingston , Texas
2 cents x 2
Siegmann is offline   Reply With Quote
Old 03-19-2016, 05:58 PM   #27
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Yes, why not? Seems like a perfect application for a "Nyloc" nut.
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
need creative ways to build supports for awning teachndad Awnings 4 07-18-2010 06:45 AM
Awning supports Minnie's Mate Awnings 9 12-06-2008 11:11 AM
Interior Rear Supports?? BornToRock General Interior Topics 0 08-23-2005 10:54 PM
Gas Line Supports Falling Off gklott LP Gas, Piping, Tanks & Regulators 5 06-23-2005 02:42 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
