Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 02-09-2010, 07:59 AM   #1
arcamedies's Avatar
Profile:  1976 Argosy 22
Laurel , Delaware
Airstream Registry
Question Carefree awning missing parts ???
After installing the new awning material and pulling it out I seem to be missing something on both extension arms as well as the locking mechanism on each side for storing against the trailer. Never having an older style (the carefree PDF file doesn't show the prop and lock photos) does anyone have a photo of what it should look like?
Last edited by silverleeper; 02-09-2010 at 08:22 AM. Reason: The use of bold, large or colored fonts should be used sparingly.
arcamedies is offline   Reply With Quote
Old 02-09-2010, 08:19 AM   #2
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Airstream Registry
I can snap a few photographs as soon as the rain lets up. The Airstream awning is stripped off for our resotration but the one on the Avion should be accessible.
Kevin
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Old 02-09-2010, 10:31 AM   #3
Kevin245's Avatar
Airstream Registry
See if any of these help you out.
As for my lock bars. The one's on our Avion lock using pins (you can see the drill holes) through the lock bars. The one's on our Airstream (which are at home in the garage) use thread steel inserts that that allow you to pinch bolt the lock bar slides at any point you desire.
I plan to install some pressed inserts in the Avion's lock bars at some point. Let's see I think this is "to Do" task 12,379 on my list of top 100 trailer repairs to be done.
Regards,
Kevin
Oh and the green mold is just a reminder that a good Spring cleaning is in order.
Name:	View of Stowage Hook Released R.JPG
ID:	95882   Click image for larger version
Name:	View of Stowage Hook and Catch Released R.JPG
Name:	View of Lock Bar Stowed R.JPG
ID:	95884   Click image for larger version
Name:	View of Lock Bar Resting on Catch Pin R.JPG
Name:	View of Lock Bar Partially Deployed R.JPG
ID:	95886   Click image for larger version
Name:	View of Anti-Furl Engaed R.JPG
Name:	Veiw of Arm Stowed R.JPG
ID:	95888   Click image for larger version
Name:	Stowage Hook R.JPG
Name:	Stowage Catch R.JPG
ID:	95890   Click image for larger version
Name:	Stowag Catch Released R.JPG
Carefree window awning parts atobols Windows, Doors, Locks & Vents 0 03-06-2009 06:47 PM
missing parts Astrup Port-A-Frame pole awning caryewest Awnings 0 08-27-2008 10:34 AM
Carefree Awning phoney Awnings 0 08-19-2008 10:31 PM
FREE Carefree Awning Parts - Austin, TX qjktx Awnings 2 10-03-2006 07:30 PM
CareFree Awning Manual 71tradewind Awnings 0 06-15-2003 08:53 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
