Old 07-11-2012, 07:27 AM   #1
1974 25' Tradewind
Berryville , Virginia
CareFree awning instructions
My 74 airstream has a carefree awning in the curb side. Does anyone have instructions on how to open it. I have never opened it and want to inspect the awning.
batt is offline   Reply With Quote
Old 07-11-2012, 07:47 AM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Carefree has a wonderful video that you can download. I know I have it on this computer somewhere, but can't find it now. Check Carefree's website.
Old 07-11-2012, 08:50 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
IF it like the one I have...
You make sure to unlock the road latches, little black plastic clips on the arms about eye level. Then you reach up with a long rod and push the little lever at the front end of the roller, IIRC It says open and close on it. THEN you take the same rod with a hook on the end and grab the loop that should be hanging out from somewhere around the middle of the rolled up awning. If everything goes right it should unroll, you have to pull on it because you are winding up the springs that roll it back up.
Good luck!
Aaron
WBCCI #XXXX AIR #2495
Old 07-16-2012, 09:56 AM   #4
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
My 1976 Carefree Awning does not have locks per se, on the arms about 2/3 of the way up on the mounting bracket are metal blocks with a bar sticking out, press the outside of the arm in and move this bar up, this unlocks the arms, I use shock cords to keep thses block up.
Next, if the pull down strap is missing, get a helper and pull the support arms out to open the awning.
Once open take the inner arms and lock the awning open.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 07-16-2012, 10:28 AM   #5
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
Carefree User Manual
I have attached the Carefree manual, as a pdf document.
Bauxter is offline   Reply With Quote
Old 07-17-2012, 11:17 AM   #6
WBCCI 8562
1975 31' Sovereign
Thumbs down carefree awning questions
Hi, Thanks for the manual, question is: can I replace the metal end caps with the
plastic ones I have??? I see both were used. Has anyone done this???
How do the plastic ones attach, the metal have 3/16 steel rivets hold them.
Thanks a lot
ps a neighbor owes me a favor, guess what that will be
Old 07-18-2012, 07:03 PM   #7
angellhill's Avatar
1978 Argosy Minuet 6.7 Metre
Burlington Flats , New York
We were just about to open the awning for the first time on our new 78 Argosy Minuet 6.7 Metre. Since it was a little confusing, I checked on the Forum and sure enough - there was someone with the same question AND another helpful AS friend with the PDF file. Awning was opened successfully (although it does seem there should be a way to lock the crossarm into the support arm more securely). Thank you so much!
angellhill is offline   Reply With Quote
Old 07-20-2012, 10:50 AM   #8
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
This could be the wrong thread, but someone was kind enough to supply the brand of sealer for our zip dees, as one of them is leaking in heavy rain, and I can't find the post. Any help?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
