I assume you have a Carefree, A&E or Zip-Dee awning...
If you have two people and can put each on a step ladder at each end of the awning tube, you could release the mechanism so that it is in "deployment" mode, and then each of you manually twist the ends of the awning tube to unroll it until the webbing is visible. Alternatively, a single person ought to be able to do essentially the same thing from the middle of the awing tube, just by reaching up under the roll and pulling while rotating to make it manually unroll.
good luck!
