Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 08-21-2009, 09:30 AM   #1
Profile:  2008 19' International CCD
Evanston , Illinois
Can anyone figure out what happened here?
We can't figure out how the rear awning pole bracket along with the pole ended up like this--sheared in two. We thought both bracket and pole were intact when we left home, but when we got to the campground, this is what we found. We assume that the hook at the bottom of the pole was not secure and the pole whipped around in the wind. Surprisingly, there is no damage to the awning or to the skin of the Airstream.
Not that it matters now--the damage is done--but I would be interested if any of you have ideas about what could have happened.
Caryl
ID:	85806   Click image for larger version
Caryl is offline   Reply With Quote
Old 08-21-2009, 09:37 AM   #2
crispyboy's Avatar
Profile:  1981 22' Excella II
alexandria , Kentucky
Airstream Registry
My guess is that it may have been a poorly cast piece of aluminum and fatigue eventually found the weak spot. Just a guess.
crispyboy is offline   Reply With Quote
Old 08-21-2009, 09:40 AM   #3
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
I have never seen that one before. You sure are lucky that the loose pole didn't beat the crap out of the back of the trailer.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 08-21-2009, 09:50 AM   #4
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
could a low hanging branch got caught in the hardware and yanked it?
one other thought would be a sign on a post came out and grabed it snapping the bracket.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 08-21-2009, 11:39 AM   #5
Lumatic's Avatar
Profile:  1971 25' Tradewind
1967 24' Tradewind
Estancia , New Mexico
Did you loose the rafter arm as well?
get off the road hippy
Old 08-21-2009, 12:29 PM   #6
BDandTTs's Avatar
Profile:  2005 22' International CCD
Huntington , Vermont
Images: 49
Airstream Registry
Contact ZipDee
Ours broke also and when we called ZipDee to order a replacement they indicated that the piece had broken on other Airstreams as well. Our awning was relatively new at the time, and the part was replaced free of charge. ZipDee is a great company to deal with, and their awning is also first rate.
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
http://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
Old 08-21-2009, 01:28 PM   #7
Evanston , Illinois
Yes, we did lose the awning pole. Since we live in the Chicago area, I did take the Airstream over to Zip Dee in Elk Grove Village. And, yes, they are super to deal with. Although they didn't mention any weakness in the metal or mention that they had seen this break before, they did not charge labor to replace the part. They are definitely into great service.
Old 08-21-2009, 05:40 PM   #8
camper collector
Profile:  1997 30' Limited
Americus , Georgia
Looks like due to the pressure of the support arm on the locking/travel catch caused the pot metal piece that broke--this ie due to Chicago area bad roads ----
camper is offline   Reply With Quote
Old 08-21-2009, 06:30 PM   #9
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
That's a weird one...glad there was not more damage.
Just for the heck of it, we lash the two arms of the Zip Dee together when we travel...using a velcro cord wrap... we put one at the upper end at the narrowest point and one at the lower end at the narrowest point...don't know if it would help if something actually broke, but it does stabilize the poles some so they don't vibrate as much.
TB & Greg...& Cockers Annie & Sadie
AirForums #21900 . Membership Chair, 4C
Unit #3954
Inside Our Bambi: AZBambi Décors
Old 08-31-2009, 02:16 PM   #10
BlackRubi's Avatar
Profile:  2007 25' International CCD FB
Dallas , Texas
Hi Caryl -
Not sure if there's a cause and effect associated but...
During our current trip i was closing the awning during a wind and noticed that the nut holding the rear rafter arm was missing. The bolt had worked it's way about halfway out and was torqued (seemingly from stress during travel). I can imagine that at speed, and not properly secure, the our bracket could've sheared in similar fashion.
Upon further inspection - i found that the corresponding nut/bolt on the forward rafter arm was also very loose...
Would be very interested to see if others are finding the same issues at the connection points.
All the best -
BlackRubi is offline   Reply With Quote
Old 10-20-2009, 08:13 PM   #11
redhawkerII's Avatar
Profile:  1970 27' Overlander
no cities , Traveling
Images: 14
Send a message via Yahoo to redhawkerII Send a message via Skype™ to redhawkerII
Yeah it looks like poor casting defect to me too, what else is there that it could be?
...Lots of people want to ride with you in the Limo, But what you want is someone who will take the bus with you when the Limo breaks down....http://smileys.smileycentral.com/cat/23/23_30_126.gif
redhawkerII is offline   Reply With Quote
Old 10-21-2009, 10:33 AM   #12
Profile:  1977 21' Globetrotter
Davis , California
Smile Broken rear awning pole - speculation
My totally speculative response is that the pole popped off its pin at the bottom, and moved away from your trailer, and hooked on some nearby (relatively stationary?) object. The leverage of the bottom section of the pole is about 4:1, given the relative lengths. so it might not take much to snap the bracket. I think you may have lucked out in that it was probably not a vehicle or person that was the stationary object, and of course, did no significant damage to your trailer.
My poles rattle a lot due to age, so I use a couple of velcro straps around each pair to prevent noise and movement while travelling. Hope that helps avoid any future problem.
Mark
flyflinger is offline   Reply With Quote
Old 10-21-2009, 10:37 AM   #13
Mike Leary's Avatar
Profile:  Winnemucca, , Nevada
Count yourself lucky, we came south on 95 out of Las Vegas the other day in a windstorm;
saw three coaches on the side of the road with blown-out awnings.
1983 310 Turbo Diesel w/ o.d. "Bess", 216,005 miles
Full timers since 1994
Mike Leary is online now   Reply With Quote
Old 10-21-2009, 02:09 PM   #14
Evanston , Illinois
We, too, have been using velcro straps on both awning poles to reduce vibration as several suggested on this thread. When we have the repair work done at Zip Dee, the technicians also tightened and adjusted all three awnings. We have noticed that they are all tighter and snugger than before the accident. We are happy campers now and feel like we missed a bullet in this incident.
Caryl
Can't figure this out streamdreame Steps 6 04-09-2009 01:32 PM
Help me figure out what this is Lumatic General Interior Topics 3 10-22-2007 07:50 PM
How can I figure out the towing capacity of my 300TE? davida Tow Vehicles 5 06-05-2006 05:07 AM
Any newbie worth his/her salt should be able to figure this out for her/himself... Dave Jenkins Our Community 4 07-26-2003 05:41 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
