Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 05-22-2012, 08:02 PM   #21
1985 31' Excella
Fresno , Texas
I was able to straighten mine with it on the trailer. Put the bow aligned to the support kickers and blocked them with 2 x 4's and then put the bent tube under my armpit and gently nudged it out with short forceful bounces. It still works and its been about 7 years ago. PS I didn't have the bottom supports out all the way.
Wsmith is offline   Reply With Quote
Old 05-23-2012, 09:29 AM   #22
Boerne , Texas
Images: 18
Yup. Price os 7.90/ft + 25 for shipping tube + shipping fee +/- 300.
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley. 1600 Watts Solar/ 400Ah Lithium batteries
Tow With: 2006 Dodge 2500 Quad LB 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Old 05-24-2012, 11:01 AM   #23
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Cool bent awning tube
had to replace mine, even though the bend wasn't to bad, couldn't get it straight, and $300 was the number for the tube.
arcamedies is offline   Reply With Quote
Old 05-24-2012, 03:09 PM   #24
dznf0g's Avatar
Oswego , Illinois
If any of happen to be passing through the Chicagoland area, the Zip Dee rep also told me they could do a complete bend, reshape and adjust the whole setup for about $100 an hour, and it takes about 1 to 1.5 hours. Parts, if required, would be extra.
-Rich-
Old 06-23-2012, 01:26 PM   #25
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Bent Rafter Arm Bar
Last month I was sitting under our main awning in the desert when a sudden, unexpected, renegade dust devil lifted one end of the awning and bent the rafter arm bar and put a slight bow in the arm tube.
Upon return home, I ordered the appropriate replacement rafter arm bar and tube from Awnings By Zip Dee (See details in my posting, "Desert flowers and devils".)
I installed the new rafter arm bar and tube.
The slight bow in the old rafter arm tube self-corrected itself when the bent rafter arm bar was removed from it.
Larry used a Black & Decker Workmate workbench vise and PVC pipe to straighten the bent arm bar. The photos below were taken after he straightened the bar and are presented here to show how he did it.
First he placed the bar on the flat workbench surface to check for straight (true) bar alignment and used a marking pen to mark the bent section.
He marked the bar in 3 places and placed the bar in the workbench vise at the 1st mark for bending with a PVC pipe (See post below).
Name:	DSC_0064 Bent Rafter Arm Bar.jpg
ID:	161641   Click image for larger version
Name:	DSC_0131 Checking bar alignment.jpg
Name:	DSC_0132 Marking bent portion.jpg
ID:	161646   Click image for larger version
Name:	DSC_0133 Bar in vice at 1st mark.jpg
SilverGate is offline   Reply With Quote
Old 06-23-2012, 01:33 PM   #26
SilverGate's Avatar
2007 23' Safari SE
Bent Rafter Bar Repair (continued)
A PVC pipe was used as a lever to gradually straighten the bend. The bar was advanced into the vise to each succeeding mark and the PVC pipe was applied until the bar was straightened and easily slid into the arm tube.
Now we have an extra rafter arm bar and tube on hand for that next dust devil!
Name:	DSC_0135 PVC pipe to straighten bend.jpg
ID:	161648   Click image for larger version
Name:	DSC_0137 Bar at 3rd mark for bend correction.jpg
Name:	DSC_0142 Rafter arm bar in tube.jpg
Old 09-16-2018, 10:22 AM   #27
Kensington , Maryland
Those Rafter Arm Bars are very strong. Mine had a bend nearest the top and took some serious persuasion to correct. The (above) video is on the money, just hook it in the trailer frame and spring it back into shape. Use a fine flat file to remove the score marks left by the trailer frame and spray lube with Boeshield.
For those of us who are less industrious the part is only $39 from Outofdoorsmart.com
*Note* I will never go out to dinner and leave the awning extended again.
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 09-17-2018, 10:44 AM   #28
Ray Eklund's Avatar
2019 27' International
2014 25' International
Boulder City , Nevada
A common mistake. Understand how to set your awning in wet or windy conditions.
There is a lengthy Awning list under Boondocking 101... it will save you future grief.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 09-17-2018, 11:53 AM   #29
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Go to a muffler shop and get a new tube cut to length.
They offer galvalum so it will not rust.
Cheap and no truck freight fee.
Old 09-25-2018, 06:02 PM   #30
snappykelly
snappykelly's Avatar
1986 25' Sovereign
North Bend , Oregon
I’m sorry I don’t know how to start a new post. I have an ‘86 Sovereign new to me. The door-side awning part 3B (see photo) seems broken. There is an end in the tube and I can’t open the awning entirely, even though I received pictures of it “Perfectly open” before buying in “ready to camp” condition but also of course “as is”. One month later, one new converter and fuse box, new lug bolts on one wheel, I haven’t camped YET! Is 3B broken? Click image for larger version
Kelly Barnett:
snappykelly is offline   Reply With Quote
Old 09-25-2018, 06:03 PM   #31
snappykelly
1986 25' Sovereign
North Bend , Oregon
Kelly Barnett:
Zip Dee awning for '61 Tradewind 61 Streamy Awnings 10 03-27-2013 08:49 PM
Replacing Zip Dee awning canvas webspinner Awnings 23 02-06-2012 06:03 PM
Zip Dee Awning Problems lmcatee Awnings 4 01-08-2012 10:33 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee Awning Repair - Golf Cart Accident jbbaldwin Awnings 0 08-15-2011 01:16 PM
