Old 03-26-2013, 08:12 AM   #15
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Pileus View Post
Skater,
I have been reluctant to disconnect the rear arm on my awning which is stuck because I didn't want it flailing around under the tension of the spring beating up my Airstream and possibly breaking my arm.
Then I read this comment on another thread:
"With the awning rolled up and locked in place with the wheel locks, you can remove the lower arms completely and the roller tube springs will not be in play. Take off the arms and the end rafters and see how much you have to play with. Also an opportune time to clean everything and lube with silicone spray."
I'd like to confim this with Zip Dee.
I can confirm that is what I did when I bent my arm and had to replace the lower rod and its corresponding tube.
-Rich-
Old 03-26-2013, 08:56 AM   #16
Pileus's Avatar
1985 31' Excella
Seguin , Texas
Posted by Skater:
That's good news if it's true, but I can't see how the tension would be off of it - as far as I'm aware, the lock just prevents the tube from spinning, and I expect the spring would still have at least some tension on it, so that arm is basically always being pushed toward the side of the trailer. I'd be happy to be wrong, though - an easier repair is good.
Are you planning to call them? If so, I'll wait to hear what you find out, rather than bugging them repeatedly with the same question.
___________________
I just spoke with Linda at Zip Dee. She confirmed that if you have the head secured to the trailer with the wheel locks, you can safely remove the arms.
Pileus
Pileus is offline   Reply With Quote
Old 03-26-2013, 09:09 AM   #17
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I think posters are talking about the arm locks not the roller lock.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-26-2013, 09:10 AM   #18
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Good to hear. Thanks, everyone! I'll still be careful when I remove that bottom bolt, but I'm sure I'll be able to tell pretty quickly whether the tension is still there.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 03-26-2013, 03:44 PM   #19
Pileus's Avatar
1985 31' Excella
Seguin , Texas
The wheel lock secures the end casting of the roller assembly to the body of the trailer.
Name:	1-ZIPDEE 004 (2).JPG
Old 03-26-2013, 05:05 PM   #20
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Yeah. Obviously I was thinking of the other lock that prevents the awning from rolling up or down... don't know what it's called.
Old 03-26-2013, 07:45 PM   #21
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
The spring rolls the tube up to the rail on the trailer. When the awning is extended the spring is at maximum tension, when the awning is rolled up the spring is at minimum tension. The spring actually swings the arm away from the trailer in a counter-clockwise direction when looking from the rear of the trailer. The tension on the arm is not really that much when you hold it at the end. If you let it go the swinging 5' arm is what does the damage.
When you install the awning you extend the awning and while one person holds the end of the tube another person winds the spring using the arm as a lever. It is not difficult strength wise to wind the spring using the arm as the lever. It is more difficult holding the tube because is just kind of hanging out there with no support and trying to roll itself up. You are also trying to keep the fabric stretched so you don't hit the trailer with the arm while swinging the arm to tension the spring. Supporting the tube on a step ladder makes the job much easier. Also if you have the "Z" lock at the front of the awning it makes the job easier because you won't have to fight the tube rolling up while you wind the spring.
So to get to the question, yes leave the awning rolled up with the wheel locks secured and you can safely remove the lower section of the arm, what ZipDee calls the "hinge bar." Be careful that you do not move "main arm tube" because it is a long lever that can rip the wheel lock brackets out of the trailer. Have your helper stabilize the main arm tube while you remove the hinge bar. You can also remove the main arm tube from the main arm bar if you want to use the main arm tube for leverage to help straighten the hinge bar. You can check this PDF to verify the names that ZipDee uses to identify the various parts. http://awningsbyzipdee.com/media/19b...08ffffd523.pdf
I hope this helps answer some questions.
Cheers, Dan
~ Margaret Thatcher ~
Old 03-28-2013, 05:59 AM   #22
Skater's Avatar
1995 30' Excella
Bowie , Maryland
The new arm came yesterday (thank you ODM!). I was surprised by how short it was - it apparently doesn't go very far into the larger part of the arm. I was expecting something 3' or 4' long, but instead it's maybe 2' long. I'm hoping I can replace it Sunday.
Old 03-28-2013, 06:09 AM   #23
Pileus's Avatar
1985 31' Excella
Seguin , Texas
Doesn't sound right... Are you shure you recieved the main bar? Sounds more like you got a hinge bar.
Old 03-28-2013, 06:21 AM   #24
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Gulp. I used this page and picked the one that said Satin '94-'98 (I have a '95), which is the part number that is showing on my receipt. It's possible I got the wrong one - I did only take a quick look, and I haven't taken the old one out yet so I can't compare to that one.
Old 03-28-2013, 07:53 AM   #25
dznf0g's Avatar
Oswego , Illinois
It's not very long. Bolts into the tube and is inserted about 1 foot at the most. It was the lower bar that bent on yours, right? Mine was the upper bar. But mine bent from pooling rain while the awning was deployed.
I think you're fine. It only goes up about an inch past that acorn nut in your pic in post #1.
-Rich-
Old 03-28-2013, 09:09 AM   #26
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
ZipDee has good youtube videos on their awning products from setting up, to fixing and maintenance.
switz is online now   Reply With Quote
Old 03-28-2013, 04:49 PM   #27
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I think you're right. For the record it's just over 25" long. Holding it up next to the camper, it stopped just below the acorn nut that's in front of the blue stripe in my picture, but one of the holes in the new hinge arm lined up perfectly with the horizontal bolt near the bottom of the main tube. (I compared it to both arms on the camper since the bent one is harder to compare.)
Also, I was struck by how much nicer the new arm looks compared to the rest of the awning that has been out in the weather for 18 years. Hopefully it'll quickly oxidize a little bit and blend in again.
Old 03-28-2013, 05:21 PM   #28
dznf0g's Avatar
Oswego , Illinois
Rub a little automotive cleaner/wax on the rest of the pieces. They'll shine up a bit when some oxidation is removed.
-Rich-
