Old 11-13-2017, 12:59 PM   #1
1970 23' Safari
Thomasville , Georgia
Bar and tube stuck
Has anyone ever encountered the main arm bar and tube, on a front awning, seizing up? I am having that problem on one side, and am unable to extend the awning (arm) or remove the bar from the head casting. I'm afraid to apply too much pressure, but have given it a pretty good try. Thoughts? Maybe some way to pull apart without breaking something else? - Thanks
Middy is offline   Reply With Quote
Old 11-13-2017, 01:47 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I am having difficulty picturing exactly what is seized up. Can you post a picture?
Tom
Old 11-13-2017, 03:57 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think I know what you mean. I have had the sliding part freeze up. The arms get water inside and the Al part corrodes. I was able to get mine loose. Inspect to see if it has been dented or buckled or frozen and cracked. Be very careful of the spring tension on the awning. if you take that arm out of the head you have to deal with the spring first. Lots of Hi Tech lubricant might get there eventually, ..or not. I do not know a magic way to get it loose. Vibration, tension, and lubricant and watch out for the spring are all I can offer.
Bill M. is online now   Reply With Quote
Old 11-13-2017, 05:34 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Zipdee, Carefree, EZ Awn, awning?
It does not take much of a bend or just a bit of oxidation to bind it up.
Once you get it free regularly spray the parts with silicone (not WD 40)
When did you last have it open?
Old 11-14-2017, 08:15 AM   #5
1970 23' Safari
Thanks. I'll keep trying. I bought it as it is now. I have definitely been worried about taking the arm off, for fear of releasing the spring tension. It's a Zip Dee.
Old 11-14-2017, 10:29 AM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Zipdee design has not changed for decades. They are also very customer friendly. You could give them a call.
1979 Zip Dee awning, spring stuck in tube Bowmans Awnings 2 07-24-2016 12:33 PM
ZD rear main bar stuck - unable to adjust RuneM46 Awnings 2 11-07-2014 07:18 PM
grey bar and red bar compound capt ken Cleaning, Stripping & Polishing 4 10-02-2013 11:17 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
