Old 04-10-2005, 10:34 AM   #1
Uberlanders's Avatar
1968 26' Overlander
Wenatchee WA , Cape Cod
Awnings
We just purchased a 68 Overlander. We noticed an awning track on the outside of the trailer. Is this track used to attach the manufacturer's awning or is it for some sort of removable canvas awning where you slide the beads into the track. Attached is a picture of the track...would love input.
Name:	Awning Hardware 2.jpg
Uberlanders is offline   Reply With Quote
Old 04-10-2005, 10:44 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Awnings
Greetings Uberlanders!
Welcome to the Forums and the world of Vintage Overlander ownership!
By the 1960s, the awning rail was a standard feature on Airstreams. The actual awning selection was left up to the owner. Pole-type awnings were most common early in the decade, but by mid-decade there were a number of manufacturers of "permanently mounted automatic" awnings including such brands as ZipDee, Carefree of Colorado, and A & E Systems -- today, the only company that seems to reliably support the Vintage market with "permanently mounted automatic" awnings is ZipDee (most of the others have quit making the curved awning support arms that fit the curvature of our Vintage coaches). You can find ZipDee on the web at:
http://www.zipdeeinc.com/
Pole-type awnings can also be sourced locally in most larger cities from shops that make canvas awnings for businesses and homes. They are typically a bit less expensive than the "permanently mounted automatic" awnings, but on an Overlander will likely require two people for the install remove process as the awning fabric must be removed prior to travel which usually means standing on a ladder when installing or removing the fabric.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 04-10-2005, 10:53 AM   #3
1968 26' Overlander
Wow! Thanks for the quick feedback! We were hoping it was for a pole awning! I guess were purests, I'm sure after a few years of threading the eye of the needle we might change our minds.
I would like to make it myself. Any idea what the hardware is called that threads through the track?
Old 04-10-2005, 11:36 AM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I just got a vintage-type awning made for our GlobeTrotter.
It actually has a plastic tube that feeds through the awning rail, it's in a awning fabric casing. I've also seen rope used, but I would think it wouldn't be as stable as the tube and might stretch.
Good luck in whatever you decide to do!
Shari
Old 04-10-2005, 12:30 PM   #5
Owings Mills , Maryland
Images: 8
The trailer my parents had in the 60's had a vinyl part that went in the rail. I looked for something just like it although I didn't know what it was called. Rochford Supply calls it vinyl beaded welt. Here is a link to their page. http://www.rochfordsupply.com/produc..._ProdID_E_3517
Marine supply stores usually have it in different colors, and often you can get it locally. That is what I plan to use.
Kaye
Kaye and Lynn
1961 Caravel
kayelm is offline   Reply With Quote
Old 04-10-2005, 01:49 PM   #6
1968 26' Overlander
Shari & Kaye,
We would have never thought it was a continuous vinyl tubing. Thanks for the website info. It looks farely inexpensive. Now I just need a pattern, I added that to the other awning discussion today.
Thanks also to the forum in general for making us so welcome. I hope someday we will be able to give advice as well to return the favor.
Jim & Kathleen
1968 Overlander - WBCCI #5793
Old 04-10-2005, 05:40 PM   #7
mbatm01's Avatar
1963 22' Safari
Broomfield , Colorado
For those that use the Pole type awnings - I know some types roll up into a bag that hangs on the rail for travelling and that there is some concern about the bag scratching the aluminum skin.
If you dont use the hanging bag - does that mean you install the awning on the rail each time you want to use it? How long does that take?
Kevin
mbatm01 is offline   Reply With Quote
Old 04-10-2005, 05:52 PM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
Kevin
We don't use the bag for that very reason...it only takes about 10 minutes to set it up...but ours is a shorty...longer ones may take a bit longer. The valance of the vinyl awning we used last year scratched the ends of the trailer at the awning rail pretty bad from flapping in the wind, I can't imagine leaving the whole awning bag on, flapping down the road. Our scratches will buff out pretty easy...just one season.
ZipDees are fixed so they don't have this problem...the bags just hang from the rail.
Shari
Old 04-10-2005, 09:45 PM   #9
mbatm01's Avatar
1963 22' Safari
Thanks, Shari.
We have a 63 Safari that we are getting close to completing the renovation on. If all goes well we will make it to the Maintenance rally in May. The awning is a tough decision - I like the vintage look that you achieved. We have decided we definately do NOT want an awning with the side supports bolted to the shell. I have seen some slick awnings like Carefree Colorado that offer Pole and Stake awnings in catalogs - mostly for pop ups, but not sure what will work.
Do ZipDees and Carefree awnings just roll into the bag with the poles and you are finished?
Kevin
Old 04-10-2005, 10:08 PM   #10
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Awnings
Greetings Kevin!
Thanks, Shari.
Kevin
ZipDee and Carefree of Colorado are both manufacturers of "permanently mounted automatic" awnings. Both have permanently mounted side arms (I believe that the Carefree arms are more of a rectangular box section while the ZipDee are a much smaller nearly square box tube). The awning material is attached to an awning roller tube that stores against the coach's awning rail -- in the case of the ZipDee, the awning fabric is covered by an aluminum cover when stored that is automatcilly deployed when the awning is stored.
So far as I know, ZipDee doesn't produce any pole-type awnings, but the ZipDee fabric can be purchased from awning specialty shops in a wide variety of color combinations -- one of my good friends had a pole-type awning made for his '60 Overlander from the "Fancy Blue" fabric that is often used in ZipDee awnings found on Airstream coaches. I know very little about the Carefree of Colorado line other than having seen several of their "permanently mounted automatic" awnings on mid-1970s Airstreams at various rallys -- they may offer pole-type awnings, but I don't believe they are in the ZipDee product line based on their website and the literature that I have seen at my Airstream dealer.
Kevin
Kevin D. Allen
AIR #827
Old 04-10-2005, 10:53 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 108
Exclamation Kevins...
Thanks, Shari.
Kevin
Cool! Hope to meet you soon...even if you only make it out to the May Maintenance Rally for a day sans a trailer! There are usually a dozen of so of vintage trailers at this rally...it would be a great time to check out different awning options...there's some of everything! I know of at least one Carefree awning and one A&E Trimline that are planning on being there...along with 30+ ZipDees both on new & vintage trailers.
Originally Posted by overlander64
<snip> but the ZipDee fabric can be purchased from awning specialty shops in a wide variety of color combinations -- one of my good friends had a pole-type awning made for his '60 Overlander from the "Fancy Blue" fabric that is often used in ZipDee awnings found on Airstream coaches.
The manufacturer of the fabric that ZipDee makes their awnings from is Sunbrella. As Kevin mentioned it's available from awning shops and online.
Shari
Old 04-11-2005, 08:49 AM   #12
Shari & Kaye,
My brother-in-law stopped using the old canvas awning with the "add-a-room option that my dad bought for his 73.
My dad passed away 19 years ago and the awning has been in storage ever since. It is still like new. My dad NEVER left it attached to the trailer in the winter. We took it down and stored it indoors EVERY fall.
If you would be interested, I could ask my brother-in-law if he wants to part with it and how much he would want for it.
Anon is offline   Reply With Quote
Old 04-12-2005, 08:33 PM   #13
1968 26' Overlander
Thanks so much for the offer Lou. I think that we are going to purchase a pole awning from tcti. I think that's the name. It is were Insideout got hers. As I have researched price of fabric locally, with hardware, and elbow grease, I don't think I can make the awning for much cheaper. I'll be sure to keep you all informed.
Kathleen
Jim & Kathleen
Old 04-15-2005, 02:13 PM   #14
Martha's Avatar
Images: 38
Zip Dee awning
After installing our new drapes into our 68 overlander (26') (from James P. Ambruso, Inc.), we are now ready to move on to the awning.
Talked to Zip Dee this AM...yow! Lots of parts to the hardware!
Has anyone ordered from Zip Dee and installed the curved awning apparatus themselves?
http://www.zipdeeinc.com/CurvedAwnOp.html
We are "DIY-ers", but would like to hear from those experienced.....
(I am posting pictures of drapes this weekend!)
Martha is offline   Reply With Quote
How long is your Airstream Trailer? InsideOut Community Polls 106 07-31-2008 02:42 PM
Vintage Looking Awnings... InsideOut Awnings 143 03-15-2007 12:00 PM
My 1974 Sovereign with rear twins gvanman 1974 - 1979 Sovereign 18 04-03-2006 07:16 PM
What color are your awnings smily Awnings 44 08-01-2005 12:45 AM
