Old 06-19-2007, 07:24 PM   #15
1989 34.5' Airstream 345
Silverton , Colorado
Our '68 Overlander had the same thing happen in northern AZ on IH40...it was a new(1 yr old) ZipDee, curbside. I saw the shadow of the unfurled awning in the rearview mirror. It bent the long tube at the front and pulled out the front 6 rivets. Oasis RV, in Tucson, repaired it, but we used bungee balls to insure no recurrences. 'spensive lesson, but could have been worse...........mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 09-28-2007, 09:05 PM   #16
SoDakStreamr's Avatar
1972 27' Overlander
Aberdeen , South Dakota
awning opening ....
Yes, the awning in question is on the street side, and does not have the two arms located on the curb side to ensure it stays put. It just happened again this past weekend, with about 50-60 mph gusting winds from the 'street' side of the camper. Very scary stuff when you picture your camper, truck and family overturned into a road side lake.
This time, I even tied the arms with rope, across the camper to the curb side and the awning tried to unfurl, but couldn't quite do it. Just doen't seem normal, but most other campers built today have a dual bar setup, with locks to prevent this type of problem. I've never noticed this simple 'pull the strap' type of awning retraction system without any type of locks on any other camper. Expect it may be unique to the AS.
I'm guessing that my only real option is to drill a hole to install a stud into the side of the campe and lock the arm to the stud while traveling, similar to the curb side setup.
Thanks for the input.
SoDakStreamr is offline   Reply With Quote
Old 09-28-2007, 09:11 PM   #17
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Brad,
If you have a ZipDee awning, they make a latch which fastens to the side of the trailer and to the metal awning cover. Give them a call, the price is less than $10 as I remember.
Bill
Just my personal opinion
Old 10-24-2007, 06:07 AM   #18
1992 34' Excella
Punta Gorda, , Florida
Let's go back and read his question again. It's the driver's side awning that's giving him a fit. If in fact it's 24' then I'd say he has another problem. The hook is the only solution for that awning. Check some boneyards like the one in Missouri for that hook someone mentioned. Colhart or someting like that. Google it. Might find it. I might be ableto find it. PM me or email and I'll find it for you. 60 mph? True Story?
FlaAirstream is offline   Reply With Quote
Old 10-24-2007, 06:47 AM   #19
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Had same problem with a MOHOME the items wkerfoot suggested solved the problem.
jkcru is offline   Reply With Quote
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Awning Heads Up!!! JaceBeck 1999 Safari 39 04-25-2006 05:31 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Awning gwrimmer General Motorhome Topics 1 11-07-2002 11:59 AM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
