Old 10-14-2013, 09:59 AM   #1
Airstream fanatic
Grapes's Avatar
Bouse , Arizona
awning trouble...
So, we took the awning out when we were boondocking in Quartzsite and during the night a big gust of wind took over half the awning off the track!!! It didn't rip (thankfully) but now we can't use the awning does anyone know where I can get the awning fixed and back on its track? Its a Carefree awning if that helps! Thanks!
Cass
1979 Sovereign International (Olivia)
1986 F-250 4X4 (Oscar)
BLOG: http://grapesbigadventure.wordpress.com.
Grapes is offline   Reply With Quote
Old 10-14-2013, 10:17 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It is easy to fix....but dangerous if you don't know about the spring loaded ends. You will need help on a long awning like you have. Stabilize, restrict the springs from motion. Disconnect the arms from the roll ends and lay the arms out on the ground. take the retaining screw out of the awning rail and slide the roll out that end. This is where your friend/helper comes in. If you have t, spray a little silicone lubricant into the now empty rail. Inspect the awning for damage and if OK....slide it back into the rail and reinstall the retaining screw. Swing the arms up and reattach if the spring was restricted as mentioned. WARNING!!!the spring getting away has caused severe injury and finger/thumb loss to careless installers. There is a reference to A&E/Carefree awning manuals on the WEB.
