Old 06-28-2007, 09:53 PM   #1
Beneath the title
jnerges's Avatar
2005 28' International CCD
Mount Pleasant , South Carolina
Awning seems low? Bumps the Door
Hi, I have a 28 foot Intl'. I got an inservice on how to set up the awning but the door bumps it when I open it. When it stays open, no troubles.
How high up should it go and how do I know I have set the awning to max height? Does this make any sense?
Thanks AS Friends,
John
Aunt Gladys, 28FT, Intl'
"Man, it's hot here, is the heat on?"
jnerges is offline   Reply With Quote
Old 06-28-2007, 09:56 PM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Do you have a ZipDee brand awning?
Michael
ArtStream is offline   Reply With Quote
Old 06-28-2007, 10:38 PM   #3
_
hi john
don't know the year of your trailer...
let's pretend it's recent
with the current line of zipdees (post 1989) there are 4 holes or positions for the snap stud on the main arms.
i almost always use the 4th hole for the main awning arm nearest the door, this is the fully raised position.
and the 3rd or 2nd hole for the snap stud on the distant arm. the slope is absolutely needed of rain.
depending on awning length 4/3 usually clears the door while 4/2 just lightly rubs.
and don't forget to lock the rafter arms before raising on the main arms...
zipdee has a nice website and the user guide online, maintenance and so on...
cheers
2air'
Old 06-28-2007, 10:39 PM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
John,
What does the statement above mean? Door bumps it when it is extended, or when it is rolled up?
Uwe
www.area63productions.com
Old 06-30-2007, 03:10 PM   #5
Beneath the title
jnerges's Avatar
It's a Zip Dee
Thanks all for the help. When the awning is open, The door rubs the canvas on the way open. I will double check to make sure I am on the 4th hole.
More to follow
John
Old 06-30-2007, 03:13 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The fabric may have a little sag to it as well. See if you can adjust the rafter arm to the next detent by pulling outward from the trailer.
Richard
Old 06-30-2007, 03:45 PM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
My ZipDee need to be in the fourth hole for the door not to rub on it. When it's in the third hole, it appears to be fully deployed, but it is not. Be careful to stop at the fourth hole. It is not far past there where the support rod separates. Set the end opposite the trailer door at the third hole when it rains, so that the ZipDee drains properly.
SuEllyn & Brian McCabe
Old 06-30-2007, 03:55 PM   #8
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Should be on the 4th hole setting. Mine rubs too if I use just three on the Zip Dee arm.
Old 06-30-2007, 04:11 PM   #9
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
I simply lowered my door, was the big deal!
Michael
Old 06-30-2007, 05:05 PM   #10
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Artstream, Michael, could you post a pic of that please!
Kistler
Kistler is offline   Reply With Quote
Old 06-30-2007, 05:38 PM   #11
Some of the pre-1985 ZipDees did not have a 4th hole.
My Argosy Minuet did not have a fourth hole.
Neither did my original ZipDee on my 1977 Argosy 22 or the 1976 Argosy 24.
All I did was raise it up and it "bit into" the arm. It works fine that way.
I did eventually drill a couple detents in the lower arm so it would stay.
Not sure if all of the older ZipDees had the missing fourth hole or not.
Anon is offline   Reply With Quote
Old 06-30-2007, 08:29 PM   #12
Beneath the title
jnerges's Avatar
The 4th hole is a winner
The 4th hole is a winner. The bars were kind of stiff to pull out so I only had them out to a 3. Since I am a novice, I only had them on 3.
And then I figured out I was placing the brace on the middle bolt, not on the awning spindle. It works great. Which goes to prove that is a great web site.
Thank you for your help. The Zipp Dee web site was'nt bad, I found an illustration that clued me.
John
Name:	AS Awning.jpg
Old 06-30-2007, 09:59 PM   #13
tinhutjohn
tinhutjohn's Avatar
1974 29' Ambassador
London , Ontario
Images: 8
Sometimes that 4th hole is a brute to set. One additional suggestion I have is to keep the telescoping parts of the arms well lubricated. I use teflon spray as it doesn't seem to attract dirt like WD 40 or other oil based lubricants. Some of my A/S friends have a handle that fits on the support arms that gives them more grip to extend the arms.
The other trick about ZipDee awnings is to make sure you slowly let it rewind when you are taking it down. You can lose that little canvas pull tab and it's brutal to find it again if you let it "snap" back into the roller.
Sarge
74 Airstream Ambassador International
94 Burb Ontario plate "TIN HUT"
02 Jetta TDI
Logan the Large hairy Golden Retriever
It's a monocoque thing
You wouldn't understand
tinhutjohn is offline   Reply With Quote
Old 10-23-2007, 06:01 PM   #14
FishByFly's Avatar
2017 25' Flying Cloud
Oak Park , Illinois
Awnbrella
Has anyone ever used the Awnbrella awning bows?
I have a similar problem with the door rubbing on the awning. I have a 2005 Safari that is equipped with a ZipDee Awning. The last I had it ope, I checked for a higher position on the arms and didn't find one.
Our last Airstream was an '88 Excella. It had a roller on the top of the door that prevented the rubbing of the door. I inquired about having one placed on the Safari. I was told it was available but the Awnbrella was recommended to me instead.
FishByFly
because I catch fish on a fly...
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
1965 Main Door buckmaster 1965 - 1969 Globetrotter 0 10-19-2002 07:47 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
Outside handel for intrance door Sam Lawhorn Doors & Locks 2 08-20-2002 03:18 PM
door key tomb Doors & Locks 8 07-17-2002 11:16 AM
