Old 05-31-2016, 08:39 AM   #1
2014 22' FB Sport
Mpls , Minnesota
Awning retention hook gone, would you replace?
One of the two hooks that hold the awning roller during transit has disappeared on the way to a campground this weekend. Wondering how important these things really are since I would often find that they don't even stay in the "hooked" position when driving. It is the rear one that went missing, not sure if it broke or fell off. I think I could live with it if there's no compelling safety reason for them. Seems like the tension of the awning roller is what holds this closed, but if that were to fail...
MN Jeff is offline   Reply With Quote
Old 05-31-2016, 08:49 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Replace it. Odds are you'll be OK until a big double trailer semi passes you on the right.... suck that thing right open. Now is it the HOOK or the round thing that you tighten down with the awning pole? Either way, order a replacement from your local dealer - or from a salvage operation like Colaw's. (Someone out there has a "donor" Airstream or two. Just ask.)
Paula
Old 05-31-2016, 08:52 AM   #3
Tincampers's Avatar
Sneedville , Tennessee
I used Loc-tite on mine as the screw would not stay in place.
Tincampers is offline   Reply With Quote
Old 05-31-2016, 09:01 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The awning can unroll without the hook.
The locking knobs simply hold the arms and main roller against the roof. They do not prevent the roller from unrolling.
Call Zip-Dee. They are great folks, their parts are reasonably priced, and they know the product.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 05-31-2016, 09:06 AM   #5
richw46's Avatar
Lexington , Kentucky
My 23' has 2 round knobs on the top front and rear, the claw towards the rear and 4 bungee cords on the rafters. It came open on the PO, I don't want that thing coming open on me . Belt and suspenders, belt and suspenders....
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-31-2016, 09:16 AM   #6
stsammy's Avatar
2015 22' FB Sport
Toronto , Ontario
We just had the same discovery on our long weekend here. We were able to grab hardware at Can-Am since we were close by. It was under $10 for the hardware, totally reasonable.
Agree strongly with the Lock-Tite recommendation. Once you see the design, you'll be surprised they don't undo more often.
stsammy is offline   Reply With Quote
Old 05-31-2016, 09:19 AM   #7
2006 19' Safari
New Smyrna Beach , Florida
I put a couple tie-wraps around the closed arms when traveling to keep the awning from accidental opening. I don't trust the hook.
nsbcpa is offline   Reply With Quote
Old 05-31-2016, 09:43 AM   #8
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I use a clip that goes around the two rods. They can be bought at farm stores or hardware. I use the same clip as a secondary way to secure the tanks.
ID:	263602   Click image for larger version
Old 05-31-2016, 10:12 AM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
My travel hook on the big awning is very loose.
I am just waiting for it to fall off.
How do I tighten it?
I may do the clip around the 2 bars like the previous post.
It seems like the spring pressure would hold the awning against the side of the trailer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-31-2016, 10:18 AM   #10
Tincampers's Avatar
You need to get to the screw which is on top of the clamshell around the awning. Have your assistant pull the awning out far enough for you to reach the screw and the hook at the same time. Tighten the screw while holding the hook. I backed my screw out almost all the way and added a drop of lic-tite and then tightened the screw. Hasn't moved since.
Old 05-31-2016, 11:00 AM   #11
Native143's Avatar
2013 20' Flying Cloud
Dunedin , Florida
And if I don't have an assistant.. how do I reach that screw? Mine is really loose in the back. Just keep waiting for it to fall off.
Native143 is offline   Reply With Quote
Old 05-31-2016, 11:14 AM   #12
SKP46015's Avatar
Well... I would definitely do SOMETHING... in my twenty + years of RVing, I have seen or met at three RVers whose awnings were torn off enroute because a part failed or they failed to adequately secure them before departure... it was not a pretty site the day I was traveling behind a fellow Airstreamer down the freeway and his awning detached flying over the top of his trailer and doing additional damage... but fortunately not striking anything else before it came to rest in the median strip
Personally after checking that the awning wheels are locked tight and secured... I also secure the awning arms near the top and halfway down with six inch bungee ball cords like those pictured here...
ww.amazon.com/Kotap-BB-6B-Bungee-6-Inch-25-Piece/dp/B00DPLM5YU?ie=UTF8&keywords=bungee%20ball%20cord&q id=1464714457&ref_=sr_1_2&sr=8-2
Over kill? ...maybe... but, better safe than sorry I say...
Ed
94 30 Ft. Front Kitchen Excella
99 GMC 2500 6.0L Ext.Cab. 8ft Bed
ARE Shell Topper
SKP46015 is offline   Reply With Quote
Old 05-31-2016, 12:05 PM   #13
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
I've found that a loose screw for the retaining hook can enlarge the hole through the metal awning wrap
You may want to put a thin fender washer under the screw head before reinstalling the retaining hook to provide additional reinforcement.
Greg
greghoro is offline   Reply With Quote
Old 05-31-2016, 12:06 PM   #14
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
As far as securing the awning arms, a couple of velcro bands work great. Get a package of 10 from Harbor Freight for a couple of bucks. Quick, easy and don't cause any damage to arms. Would still replace the hook and use a thread lock on it.
Chuck
silverlabs is offline   Reply With Quote
Rusty Rear Awning Retention Struts – SOLUTION withidl Awnings 7 01-03-2014 04:40 PM
My beautiful Airstream is gone, gone, gone. mhilley On The Road... 55 02-12-2012 10:44 AM
That page peal is gone! IT's GONE! GONE! YES!! AIR-Quarius Off Topic Forum 2 10-11-2010 02:18 PM
Frame Rust/Belly Pan Moisture Retention?....2000 and Later Year ASs???? TomR Repairing/Replacing Floor &/or Frame 23 10-30-2009 11:17 PM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
