10-20-2008, 08:09 PM
Awning Rebuild Parts Availability
I'm rebuilding the Carefree awning on my 76. The roll tube end caps are plastic and have deteriorated. Oh and here's the shocker...they reportedly are no longer available. I plan to turn new ones from aluminum bar stock unless anyone knows of a source for them. The other question is how the heck do they come off? It looks like the aluminum ends are pressed on to the torsion spring end stud. Any help appreciated.
Kevin
William C. Swinney
10-21-2008, 06:21 AM
Silver Mist
Riverhead
, New York
Yes there's a salvage yard at exit 299 off rt 75 in Fla.
Bob's in High Springs
386-454-573
I was there last Feb he has a ton of stuff
10-21-2008, 06:38 AM
Austin
Try this site-- he seems to have mostly A&E, but I saw some Carefree parts in there as well. You'll have to dig through, the website isn't organized too well.
Marksrv.com home page
Good luck!
10-21-2008, 11:09 AM
Retired.
, At Large
Good luck!
Just an FYI, A&E is a part of Dometic now. Of course, that's subject to change at any time, with current economic conditions.
10-24-2008, 08:42 AM
Turn Baby Turn
Well I had no luck finding replacement end caps for the old Carefree Awning. So quick call to a friend got me a piece of 1" by 7" aluminum flat bar (6061T-6). Here is the progress so far.
Kevin
William C. Swinney
10-24-2008, 08:58 AM
Denton
, North Carolina
caps
Kevin
Kevin, those look great! They will be there when everything else is gone.
Here is a link to the original caps.
Dan
Dan Brown Denton NC
10-24-2008, 10:33 AM
Hey Dan,
Thanks for the tip. I have anonther unit that I plan to restore later next year. I'll give you a call and order a couple so iIcan avoid having to machine any more.
Kevin
William C. Swinney
10-24-2008, 10:46 AM
1969 18' Caravel
1978 20' Argosy 20
Richmond
, Virginia
awning progress
Please keep posting progress. I have the exact same awning problem!
I scream, You scream, We all scream for Airstream!
10-28-2008, 10:59 AM
Turn...Turn...Turn
The caps are done...Except for a little polishing of the ID.
But the funny thing is during a break from the lathe I pulled a Dometic spring set out of a spare tube we had laying around and started measuring. Hummmm.....A few calculations and 20 minutes with the stationary belt sander....I was able to modify the Dometic spring set to fit the old Carefree arm brackets. I'm heading to the mountains Thursday to do the install...
William C. Swinney
