Old 08-26-2014, 03:49 PM   #1
Marietta , Georgia
awning rail pulling away
My awning rail is trying to detach from the skin...meaning about the railing has come loose from the back to about half way up the airstream. The rivets appear to have broken off and not pulled away a hole. I'd like to re-attach but I don't know what rivets I should use...how big they should be and where to get them. I'm not a purist, so I'm okay with regular rivets that I have to seal. Any advise on the process of reattaching the railing is welcome too. Thanks!
ArtWithin is offline   Reply With Quote
Old 08-26-2014, 04:01 PM   #2
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
I'd Just Call Vintage Trailer Supply. Tell them whats happening and they'll send you the right rivets.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 08-26-2014, 04:28 PM   #3
You can only use Olympic rivets to refasten the awning rail.
If you want to use buck rivets, you would have to gut a lot of the interior.
With the Olympics use some Vulkem sealer with them.
Old 08-26-2014, 04:30 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Replace the rivets with #8 or #10 stainless pan head screws., with vulcum sealant....635 is good.
Old 08-26-2014, 08:57 PM   #5
Marietta , Georgia
Is it possible to use a larger pop rivet?
Old 08-27-2014, 07:27 PM   #6
Mixter's Avatar
1976 27' Overlander
I wouldn't do that. Pop rivets are not necessarily for applications that require strength since they are hollow. That awning rail is subjected to quite a bit of force.
Mixter is offline   Reply With Quote
Old 08-27-2014, 08:32 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Outdoors mart lists the rivets that are used to attach the zip dee awnings. Check out their website. And get some of the Temp pro (vulkum sealant).
Bill M. is online now   Reply With Quote
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
Galley cabinet pulling away from wall shinybean Cabinets, Counter Tops & Furnishings 2 09-04-2010 06:57 PM
Awning Bracket Pulling Away MTsafari Awnings 9 08-29-2010 09:20 AM
Found The Awning Rail...yikes! happydaze Awnings 1 04-29-2006 10:32 AM
