Old 06-16-2012, 11:16 AM   #1
1994 34' Limited
Oakland Twp. , Michigan
awning question
I bought a 1994 excella 34ft. and the awning is supprisingly in pretty good shape when I opened it. But when I open it I cannot get the right support arm to fit on to the bar. the one side fits but the other hook will not fit in there is not enough room. Has anyone ever had this problem? Will the roller arm move a little bit so I can get the one side in? I don t want to break anything trying to get it to fit in. Any help would be appreciated.
Hardenburgh is offline   Reply With Quote
Old 06-16-2012, 11:35 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If it is a ZipDee order a handle for the side arm. They are cheap and give you the mechanical advantage you need to coax the slot over the shaft.
Old 06-16-2012, 11:41 AM   #3
Gainesville , Florida
Try pushing out on the awning tube instead of up on the shaft. Jim
Old 06-16-2012, 12:39 PM   #4
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Being somewhat height challenged, I find it easier to use a short folding stool to push up on the roller. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 06-16-2012, 12:51 PM   #5
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I have recently begun to have the same problem. A holding washer has come loose and the roller has shifted a bit to the right - just enough to keep the claw from resting in its proper place.
It is on my list of things to fix - what I would do is call ZipDee and describe the problem and see that they recommend. If you have the time, do this and then post what you have learned.
And welcome to the Forums!!
Thanks - Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
