Old 03-31-2013, 06:06 PM   #1
Youngstown , Ohio
Awning question '68 Tradewind
We are using a vinyl yellow and white awning that we slide into track on our tradewind. We set it up with poles and rope. Is heavy and door hits it when we open sometimes. Is heavy and if rains droops. Always tightening up. Was this original back in 68? Are going to look into zip dee but was curious about what was originally used. Also, how the heck do you choose a color? Any advice or pics of zip dees? Thanks.
Splinter is offline   Reply With Quote
Old 03-31-2013, 06:18 PM   #2
Nothing was originally used by Airstream factories back then.
It was a matter of what the buyer wanted.
The most popular Zip Dee color for the vintage Airstream's is called Pacific Blue Fancy, color # 4755.
Old 03-31-2013, 06:54 PM   #3
Youngstown , Ohio
Thanks Andy. So do you think our awning we have to slide on is from 68? The ropes definitely use old hardware. Coils on the ropes to tighten.
Old 03-31-2013, 08:20 PM   #4
I have no idea as to it's age.
Sorry.
Old 04-29-2013, 07:53 AM   #5
247stream's Avatar
1986 25' Sovereign
Cedartown , Georgia
splinter i'm also on the vintage shasta forum and the awning sounds like what is commonly used on vintage trailers and what all of us with vintage shastas use. pictures would help determine if something isn't quite right with your set up or if its simply not supported enough.
this is a pic of a shasta i used to have. the awning is 8' wide x 6' deep (out from the trailer). the fabric is a very heavy weblon fabric 'sandwich' (acrylic coating, fabric, farbric and then another acrylic coating) and we used 3 poles, staked to the ground. others use a tightening system that sounds like what you describe and perhaps yours is simply worn out.
Name:	susabella prop (1).JPG
WBCCI# 1558
2016 Ram 1500 Crew Cab 5.7 Hemi
247stream is offline   Reply With Quote
Old 07-05-2013, 07:57 AM   #6
Youngstown , Ohio
That is adorable! Love your Shasta. Thanks and yep looks just like our yellow stripped awning. Ours is a lot longer so that it probably why it sags. Too heavy.
Old 07-05-2013, 08:36 AM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Most mid 60's that I have seen had Carefree awnings. They had curved support arms that matched the curve of the trailer. Most had yellow or blue vertical striped vinyl fabric. It can be a little difficult to roll up straight but we love how ours looks. It was on our Trade Wind when we bought it.
PM me if you want a link to several pics of the older style Carefree support arms. They are no longer available and as Andy said most folks now go with ZipDee.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Zip Dee awning for '61 Tradewind 61 Streamy Awnings 10 03-27-2013 08:49 PM
Do you polish your awning???? robwok Cleaning, Stripping & Polishing 6 02-11-2012 06:12 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
carefree awning fabric width johnhh Awnings 0 07-30-2011 09:16 AM
Hello All, 1970 Tradewind awning question Rollerboy Awnings 7 08-12-2008 04:53 PM
