Old 07-08-2011, 02:25 PM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Awning pull strap protection
I just finished replacing the awning pull strap on both the patio awning as well as the street side awning. Has anyone devised a way to give extra protection to the pull strap ends exposed to the sun or flapping against the side of the trailer while driving? I thought about making a sleeve out of the other awning strap material which could be slid over the ends when the awning is rolled up. Any thoughts?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-08-2011, 03:03 PM   #2
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
WOW, I never considered that will be a problem for us. I will be interested to hear the responses.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-08-2011, 03:10 PM   #3
withidl's Avatar
2002 31' Classic
Houston , Texas
When retracting the awning hold pull strap at about a 30 degree angle such that as the awning rolls up the strap rolls up more quickly; oscillate the strap from side to side so that it is essentially centered and fully rolled up when the awning is fully retracted. This leaves only the loop exposed to the air/sun and it will not flap as it is too stiff.
withidl is offline   Reply With Quote
Old 07-08-2011, 04:59 PM   #4
2007 27' Classic FB
Ridgefield , Washington
Just what withidi said. There is a link on youtube where the owner of Zip Dee awning shows how to properly do this.
John & Lisa
Woosch is offline   Reply With Quote
Old 07-08-2011, 05:12 PM   #5
davidz71's Avatar
1986 25' Sovereign
I never thought about that. Thanks.
Craig
AIR #0078
3.73 rear end
Old 07-08-2011, 05:27 PM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I have one to replace. I have had it since last fall but just have not drilled the holes and put it on. If you use the rivits that they provided with the replacement strap does it feel secure when you open / close the awning. I was thinking about using an additional washer to secure them to the tube.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-08-2011, 09:12 PM   #7
davidz71's Avatar
1986 25' Sovereign
It seemed to me that the rivets were not really long enough but the 3 per strap seem to work OK. Time will tell.
Craig
AIR #0078
3.73 rear end
Using your awning sbcohn On The Road... 29 06-14-2011 05:14 PM
2006 classic 31 door scraping awning Flying Gypsies Awnings 11 04-19-2011 07:11 AM
How do you know who made your awning? neal Awnings 4 04-03-2011 12:23 PM
Awning Hooks Kathleenh 1997 - 2004 Bambi 3 03-14-2011 11:38 AM
