Old 03-03-2008, 03:15 AM   #1
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
Awning "out of alignment"
Hi Folks,
I've just come to open my main awning for the first time this year. It is definitely "out of alignment". The whole thing has moved rear-ward in the slider. Although the answer seems simple, I'm going to resist the temptation to use what we Brits call, "Brute force and ignorance", to push the awning mechanism along the slider mount.
I suspect the method would be to roll out the awning and lock it - then retract the awning bars to take any tension off the mechanism.
Is this correct? Is there a method/trick to this?
ID:	55417Click image for larger version
ID:	55415Click image for larger version
Suggestions gratefully accepted,
Marc
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
Old 03-03-2008, 04:13 AM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
On occassion, I've had the same issue and have found that the amount of sideways tension whe rolling up the awning with the strp to be the culprit. Unroll your awning and when rerolling it back up, do so with a weave motion of the strap so side tension is shared between left and right. Takes a few times with this in mind but you'll get it. It sure beats brute strength, which is what I used to do.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-03-2008, 04:30 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It's hard to tell from the pictures, but it looks like the awning has slid to the rear where it attachés to the trailer. There should be a screw into the rail at the front and the rear of the rail to prevent that movement. Roll the awning out and see if it lines up in the rail with the arms. If not, move it forward till it does and lock it in place with the screws. They should go through the rail and the awning to lock it in place.
Richard
Old 03-03-2008, 04:58 AM   #4
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Hi Guys,
looking closely, I saw that the method I described was probably the best so I gave it a try.
ID:	55418Click image for larger version
ID:	55420Click image for larger version
By leaving the support arms on their shortest setting this allowed the awning to bow and take any pressure off the mount. This made the "brute force" necessary much less. I was able to take a small hammer to the point arrowed and give it a few taps. It worked so well I went past the mid point and had to start knocking at the other end to centre the whole thing.I found no screw holes and not wanting to put any holes into an Airstream I left it. If she drifts out again I can do this in 20 minutes.
Thanks for your suggestions,
Marc
Silvertwinkie
Hampshire, UK
Old 03-03-2008, 08:25 AM   #5
Originally Posted by Moonstruck
Hi Folks,
Attachment 55417Attachment 55415Attachment 55416
Marc
The Zip Dee slat that slides into the awning rail, "MUST" have a small sheet metal screw installed at each end of the slat, that goes thru the awning rail and the slat.
If not, then the awning can slide out of control.
Old 03-03-2008, 10:33 AM   #6
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
will do
Silvertwinkie
Hampshire, UK
Old 03-03-2008, 11:21 AM   #7
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Lift up the last flap closest to the trailer and you should find the set screws on either end.
If the aren't there they probably were and were removed or fell out. Holes should still be there. They might be covered up with road crud so you might need a toothbrush to clean things up so you can see.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Awning rail "snaps" bevman Awnings 2 08-15-2007 08:55 PM
"leaky" awning.... JohnGalt48 Awnings 2 07-18-2005 10:25 PM
