Old 03-17-2017, 07:03 PM   #1
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
Awning lubrication
What do you use to lubricate the awning slides
Picinisco is offline   Reply With Quote
Old 03-17-2017, 07:07 PM   #2
2007 25' Classic
Hutto , Texas
Silicone spray
Wanderer2604 is offline   Reply With Quote
Old 03-17-2017, 07:24 PM   #3
2017 25' Flying Cloud
Gold Country , California
Ditto
NorCal Matt is offline   Reply With Quote
Old 03-17-2017, 07:35 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use WD-40 brand silicone spray. It is an excellant all purpose lubricant with many uses around the trailer, TV and house.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 03-17-2017, 08:22 PM   #5
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
Bueno gracias.
Old 03-17-2017, 09:29 PM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We use aluminum lubricant.
Brian
SuEllyn & Brian McCabe
Old 03-17-2017, 11:35 PM   #7
65CV's Avatar
Western , Massachusetts
Blaster Advanced Dry Lube with Teflon, $4.99 at Home Depot.
Works amazingly well.
65CV is offline   Reply With Quote
Old 03-18-2017, 07:53 AM   #8
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I prefer a silicone based spray lubricant. I found that WD-40, in general, leaves too much residue over time.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 03-18-2017, 08:37 AM   #9
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
And it holds dust and grit. A dry lube is much better... silicone spray dries quickly after application leaving behind only the dry lubricating coating
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 03-18-2017, 09:17 AM   #10
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
We have used CRC food grade silicone for many years. Comes in an aerosol spray, and a pump spray. Part numbers 03040 and 03039.
Available through many hardware chains (Ace, True Value, etc.) and automotive channels. Google it.
http://www.crcindustries.com/product...grade+silicone
Ymmv.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 03-18-2017, 10:10 AM   #11
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I use silicone spray, which by the way is what Zip Dee recommends.
I prefer the WD-40 brand as I like the design of the can and the spray applicator. Note, this is not the original WD-40 product which would not be good to use on the awning mechanism because the original WD-40 product leaves a residue which attracts dirt. The original WD-40 product is also not really a lubricant but rather a water displacement product (hence the WD initials) to be used in conjunction with some other lubrication.
Bob Martel
WBCCI# 5766
Old 03-19-2017, 12:44 AM   #12
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
I used Blaster Dry Lube today. Everything slid back together great. Thanks.
Cheers....John
1977 24ft Argosy - sold.
Old 03-20-2017, 05:09 PM   #13
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Here's a series of videos from Zip Dee showing maintenance and operations (including lubrication).
Steve
Steve
Steve Bryant is offline   Reply With Quote
Hensley hitch lubrication Brian Hobin Hitches, Couplers & Balls 11 02-11-2009 07:24 AM
Hitch Lubrication? AndyPenny Hitches, Couplers & Balls 13 11-21-2007 03:59 AM
Stabilizer lubrication? Fyrzowt Jacks, Stabilizers, Lifting and Leveling 14 09-16-2006 06:08 PM
Bal Stabilizer lubrication mandolindave Jacks, Stabilizers, Lifting and Leveling 4 02-19-2004 10:51 PM
Hitch ball lubrication Kistler Our Community 9 05-12-2003 01:48 PM
