Old 09-20-2015, 04:03 AM   #1
Awning lights
Tried to turn on the awning lights for the first time on our new International. Nothing. Yes, I had it open all the way. One more little annoying thing that's gone wrong. Any ideas before I call the dealer? AGAIN!
loberg is offline   Reply With Quote
Old 09-20-2015, 05:17 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Fuse?
MICHAEL
Old 09-20-2015, 09:23 AM   #3
Nope, not the fuse. But thanks for the suggestion.
Old 09-21-2015, 12:40 PM   #4
Well, AWCHIEF, Turns out you were right. It was a problem with the fuse. Except this fuse is not where all of the other fuses are. It is located inside the wall behind the awning light switch. It is a single fuse dedicated to just the awning light. It wasn't burned out, it was simply loose. Another problem solved. I hope that's it for awhile. Thanks again.
Old 09-21-2015, 05:36 PM   #5
Plan-B's Avatar
2016 26' Flying Cloud
2016 25' Flying Cloud
1997 21' Excella
Watervliet , Michigan
I took delivery of a 2016 25FC. Tested the new awing strip LED lights and no go. It turned out not being a fuse or bad LEDs. The problem ended up being the LED dimmer switch that controls awning lights. Apparently there is more to the LED dinner switched than the old ones we are use to. I took delivery of the AS in June but traveled most the summer before returning it to warranty repair in Sept.
Dealer said this was not the first one they have dealt with and given AS took 3 weeks to send a replacement dimmer, there me more of an issue out there that hopefully now resolved.
Greg
2016 RAM 2500 6.7L Cummins, 4WD, Crew, Rear Air
Plan-B is offline   Reply With Quote
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 6 07-10-2012 06:42 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Awning or no awning? 2wheelin Awnings 11 04-06-2010 05:38 AM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
